2 Replies Latest reply on Aug 22, 2010 9:54 AM by searching123
    Edited PDF document appears on graph paper in Acrobat 9
    searching123
      I am new to writing in Acrobat.  I  am learning by following the directions on Lynda.com.  I have added the necessary toolbars.  Since then when I work in Acrobat, the screen I work on is graph paper.  When I print the PDF document, it is on plain paper-no grids.  Is it normal to have this type of paper on the screen?  I tried emailing the document to myself and there was the graph paper.  Is this normal?  I need to be sure that the recipient will not see the graph paper.  Case in point:  I need to send a PDF greeting card that I edited.  As you see, I am a total novice at this editing PDF documents.  Thank you for your help.
