7 Replies Latest reply on Aug 22, 2010 10:51 AM by Iain H
    Saving JPG to PNG using Save for the Web
    Iain H
      Morning
      I came across Paul Riggott's script for saving PSD to PNG which I changed to JPG to PSD.
      The only problem with this is that the file size in most cases is larger than the original.
      Is there a way to do a save as for the web as well?
      Here is the  original code:
      #target photoshop
      var imageFolder = Folder.selectDialog("Select top folder to process");
      var folderList=[];
      if (imageFolder != null)  {
      processFolder(imageFolder);
      folderList.unshift(imageFolder);
      createPNGfromJPG(folderList);
      function createPNGfromJPG(folderList){
      for(var a in folderList){
        var fileList = folderList[a].getFiles ("*.jpg");
         for (var z in fileList){
          var file = fileList[z];
          open(file);
          var Name = fileList[z].name.replace(/\.[^\.]+$/, '');
          var saveFile = File(decodeURI(fileList[z].path+"/"+Name+".png"));
          SavePNG(saveFile);
          app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
      function processFolder(folder) {
          var fileList = folder.getFiles()
           for (var i = 0; i < fileList.length; i++) {
              var file = fileList[i];
      if (file instanceof Folder) {
        folderList.push(file);
             processFolder(file);
      function SavePNG(saveFile){
          pngSaveOptions = new PNGSaveOptions();
          pngSaveOptions.embedColorProfile = true;
          pngSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
          pngSaveOptions.matte = MatteType.NONE;
          pngSaveOptions.quality = 1;
      pngSaveOptions.PNG8 = false;
          pngSaveOptions.transparency = true;
      activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
      Any help or support to head me in the right direction would be appreciated.
      Iain
        • 1. Re: Saving JPG to PNG using Save for the Web
          Paul Riggott Level 6
          Please try this..
          #target photoshop
          var folderList=[];
              open(file);
              saveAsPNG24SFW(saveFile);
          function saveAsPNG24SFW(fileName) {
              var desc3 = new ActionDescriptor();
                  var desc4 = new ActionDescriptor();
                  desc4.putEnumerated( charIDToTypeID('Op  '), charIDToTypeID('SWOp'), charIDToTypeID('OpSa') );
                  desc4.putEnumerated( charIDToTypeID('Fmt '), charIDToTypeID('IRFm'), charIDToTypeID('PN24') );
                  desc4.putBoolean( charIDToTypeID('Intr'), false );
                  desc4.putBoolean( charIDToTypeID('Trns'), true );
                  desc4.putBoolean( charIDToTypeID('Mtt '), false );
                  desc4.putInteger( charIDToTypeID('MttR'), 255 );
                  desc4.putInteger( charIDToTypeID('MttG'), 255 );
                  desc4.putInteger( charIDToTypeID('MttB'), 255 );
                  desc4.putBoolean( charIDToTypeID('SHTM'), false );
                  desc4.putBoolean( charIDToTypeID('SImg'), true );
                  desc4.putBoolean( charIDToTypeID('SSSO'), false );
                      var list1 = new ActionList();
                  desc4.putList( charIDToTypeID('SSLt'), list1 );
                  desc4.putBoolean( charIDToTypeID('DIDr'), false );
                  desc4.putPath( charIDToTypeID('In  '), new File( fileName ) );
              desc3.putObject( charIDToTypeID('Usng'), stringIDToTypeID('SaveForWeb'), desc4 );
              executeAction( charIDToTypeID('Expr'), desc3, DialogModes.NO );
          • 2. Re: Saving JPG to PNG using Save for the Web
            Iain H Level 1
            Hi Paul
            Thanks for the quick response.
            The files are being converted no problem, but the size of the files has not changed.
            I did a quick test - if I save to PNG 8 using the Save for the Web option in Photoshop, I got from 475kb to 172kb.
            Using the script goes from 475kb to 530kb
            Any other ideas?
            Iain
            • 3. Re: Saving JPG to PNG using Save for the Web
              Iain H Level 1
              Hi Paul
              Is there also a way to reduce the image dimensions as well in the script as this will also reduce the file size.
              Iain
              • 4. Re: Saving JPG to PNG using Save for the Web
                If you want PNG8 this should do it...
                #target photoshop
                var folderList=[];
                    open(file);
                    savePNG8SFW(saveFile);
                function savePNG8SFW(saveFile) {
                    var desc8 = new ActionDescriptor();
                        var desc9 = new ActionDescriptor();
                        desc9.putEnumerated( charIDToTypeID('Op  '), charIDToTypeID('SWOp'), charIDToTypeID('OpSa') );
                        desc9.putEnumerated( charIDToTypeID('Fmt '), charIDToTypeID('IRFm'), charIDToTypeID('PNG8') );
                        desc9.putBoolean( charIDToTypeID('Intr'), false );
                        desc9.putEnumerated( charIDToTypeID('RedA'), charIDToTypeID('IRRd'), charIDToTypeID('Sltv') );
                        desc9.putBoolean( charIDToTypeID('RChT'), false );
                        desc9.putBoolean( charIDToTypeID('RChV'), false );
                        desc9.putBoolean( charIDToTypeID('AuRd'), false );
                        desc9.putInteger( charIDToTypeID('NCol'), 256 ); //Number of colours.
                        desc9.putEnumerated( charIDToTypeID('Dthr'), charIDToTypeID('IRDt'), charIDToTypeID('Dfsn') );
                        desc9.putInteger( charIDToTypeID('DthA'), 100 );
                        desc9.putInteger( charIDToTypeID('DChS'), 0 );
                        desc9.putInteger( charIDToTypeID('DCUI'), 0 );
                        desc9.putBoolean( charIDToTypeID('DChT'), false );
                        desc9.putBoolean( charIDToTypeID('DChV'), false );
                        desc9.putInteger( charIDToTypeID('WebS'), 0 );
                        desc9.putEnumerated( charIDToTypeID('TDth'), charIDToTypeID('IRDt'), charIDToTypeID('None') );
                        desc9.putInteger( charIDToTypeID('TDtA'), 100 );
                        desc9.putBoolean( charIDToTypeID('Trns'), true );
                        desc9.putBoolean( charIDToTypeID('Mtt '), false );
                        desc9.putInteger( charIDToTypeID('MttR'), 255 );
                        desc9.putInteger( charIDToTypeID('MttG'), 255 );
                        desc9.putInteger( charIDToTypeID('MttB'), 255 );
                        desc9.putBoolean( charIDToTypeID('SHTM'), false );
                        desc9.putBoolean( charIDToTypeID('SImg'), true );
                        desc9.putBoolean( charIDToTypeID('SSSO'), false );
                            var list3 = new ActionList();
                        desc9.putList( charIDToTypeID('SSLt'), list3 );
                        desc9.putBoolean( charIDToTypeID('DIDr'), false );
                        desc9.putPath( charIDToTypeID('In  '),File( saveFile) );
                    desc8.putObject( charIDToTypeID('Usng'), stringIDToTypeID('SaveForWeb'), desc9 );
                    executeAction( charIDToTypeID('Expr'), desc8, DialogModes.NO );
                • 5. Re: Saving JPG to PNG using Save for the Web
                  Iain H Level 1
                  Hi Paul
                  You are a genius - the file size is now the same as my test.
                  You must have been working on this during my last email to you.
                  Is is possible to add in a piece that will set the size of the image to what you want it to be 640 x 480 so that I can then change in the script to suti.
                  So if the original is 640 x 480 and I want 128 x 80 and PNG8, i can do that.
                  Iain
                  • 6. Re: Saving JPG to PNG using Save for the Web
                    This uses "Fitimage"....
                    #target photoshop
                    var folderList=[];
                        open(file);
                        FitImage(640,640); //Resizes  to the longest size
                        //FitImage(128,128);
                    function FitImage( inWidth, inHeight ) {
                     if ( inWidth == undefined || inHeight == undefined ) {
                      alert( "FitImage requires both Width & Height!");
                      return;
                     var desc = new ActionDescriptor();
                     var unitPixels = charIDToTypeID( '#Pxl' );
                     desc.putUnitDouble( charIDToTypeID( 'Wdth' ), unitPixels, inWidth );
                     desc.putUnitDouble( charIDToTypeID( 'Hght' ), unitPixels, inHeight );
                     var runtimeEventID = stringIDToTypeID( "3caa3434-cb67-11d1-bc43-0060b0a13dc4" );
                     executeAction( runtimeEventID, desc, DialogModes.NO );
                    • 7. Re: Saving JPG to PNG using Save for the Web
                      Iain H Level 1
                      Thanks Paul - this works perfectly.
                      Iain
