4 Replies Latest reply on Aug 23, 2010 8:40 AM by TonyC_Helyx
    Problem with Custom Event in an ActionScript Component
    TonyC_Helyx
      All,
      I am hoping that my issue is quite minor and straight forward to sort out but for the life of me I can't figure it out.
      I have written an ActionScrip component that performs some business logic (grographic co-ordinate transformation).  The processing can take a while and relies on making calls to a number of server based process which are all working fine.  The co-ordinate transformation process is started with a call to a public method in the component by the main application.
      package helyx
      import flash.events.Event;
      import flash.events.EventDispatcher;
      import mx.controls.Alert;
      import mx.rpc.events.FaultEvent;
      [Event(name="gridConverted_success", type="flash.event.Event")]
      public static const SUCCESS:String = "gridConvert_success";
      public class GridConverter extends EventDispatcher
           private function projectCompleteHandler(event:GeometryServiceEvent):void
                     /* some logic to populate  the _mgrsGrid variable */
              var eventObject:GridConverted = new GridConverted( GridConverted.SUCCESS );
              eventObject.mgrsGrid = _mgrsGrid;
              dispatchEvent(eventObject);
      In addition to the ActionScript component that performs the transformation logic I have also coded a separate custom event that will return the output of the transformation back to the main application:
      package helyx
      public class GridConverted extends Event
        public function GridConverted(type:String, bubbles:Boolean=false, cancelable:Boolean=false)
         super(type, bubbles, cancelable);
        public var mgrsGrid:String;
      In the main application that starts the process I have the following code to add a listener for the event:
      private function init():void
           /* other logic... */
           addEventListener(GridConverter.SUCCESS, gridConvertedHandler);
      private function gridConvertedHandler(event:Event):void
          txtGrid.text = gridConverter.mgrsGrid();
      My problem is that whilst there are no errors thrown the 'gridConvertedHandler' is never called as a result of the 'dispatchEvent()' call.
      Grateful for any thoughts....
      Tony
