9 Replies Latest reply on Dec 13, 2010 8:55 PM by Erich Cervantez
    Flex 4 mx:text negative leading bug !?
    FM_Flame Level 1
      http://filip.nedyalkov.net/leadingtest/ (view source available)
      Simply when you set negative leading to the text the last line disappears.
      If you test this same example with HTML text it will work the same if no paragraphs are used. If paragraphs are used then it will work the same for the first paragraph (cutting the last line), and all the rest of the text that's after the first paragraph will be cutted too.
      I Wonder why I could find this bug posted somewhere.. people don't use small line spaces ? Does someone know a workaround or a way to fix this ? Thanks in advance.
