Dear all,
I am trying to use the FileUtilsService Find method to return a list of file in a folder.
For some reasons, it always returns empty list.
Here is the config that I am using:
Input
Directory: "c:\temp"
Regular Expression: "*"
Match Directories: "true"
Match Files: "false"
Output
Results: list
Paul
Views
Total Likes
I have duplicated the issue on my machine .....so I am looking into it. You do have a couple of issues though. The Regular Expression you have indicated is not a valid Reg Expression and accordingn to the help the output list needs to be a subtype of strings. Even with these changes I am still getiing an empty list. Can you try it on your system and validate?
Paul
Views
Total Likes
I have tried with all kind of reg expressions and I still get the same empty list result.
yes, the list subtype is a string type.
Thanks for looking into this issue,
Paul
Views
Total Likes
Just got mine to work ...here are my settings:
Directory: "c:\temp\"
Regular Expression: ".*"
Match Files: "true"
Output
Results: list of strings
Note that the directory must have a slash a the end.
Paul
Views
Total Likes
Still not working. I write a simple script to do it.
Paul
import java.io.File;
import java.lang.String;
import java.util.Arrays;
import java.util.List;
File folder = new File("D:\\temp");
File[] listOfFiles = folder.listFiles();
String [] files = new String[listOfFiles.length];
for (int i = 0; i < listOfFiles.length; i++)
if (listOfFiles[i].isFile())
files[i] = listOfFiles[i].getName();
List lstFile = Arrays.asList(files);
patExecContext.setProcessDataListValue("/process_data/javaArray",lstFile);
Views
Total Likes
