8 Replies Latest reply on Aug 30, 2010 11:06 PM by TomCreo
    problem with SWFLoader
    TomCreo Level 1
      hi i have problem with swfLoader in flex, when i close following code in click method i can easly add many swf to main application
           <mx:VBox id="content" width="100%" height="100%" ></mx:VBox>
        <mx:Button click="doIT()">
            public function doIT():void
                  var swfLoader1:SWFLoader = new SWFLoader;
                 swfLoader1.source = "DayProfileElement.swf";
                 swfLoader1.percentHeight = 100;
                 swfLoader1.percentWidth = 100;
                 swfLoader1.name = "a";
                 swfLoader1.id = "b";
             var panel1:Panel = new Panel;
             panel1.percentHeight = 100;
             panel1.percentWidth = 100 / 4;
             panel1.name ="c";
             panel1.id = "d";
             panel1.addChild(swfLoader1);
             content.addChild(panel1);
      it works when i push the button like once per second, but when i do it very fast i have following error:
          TypeError: Error #1034: Type Coercion failed: cannot convert mx.core::ClassFactory@a93a671 to mx.core.IFactory.
           at mx.charts.series::AreaSeries/get legendData()[C:\work\flex\dmv_automation\projects\datavisualisation\src\mx\charts\series\ AreaSeries.as:327]
           at mx.charts.chartClasses::ChartBase/get legendData()[C:\work\flex\dmv_automation\projects\datavisualisation\src\mx\charts\chartCl asses\ChartBase.as:1161]
           at mx.charts::Legend/populateFromArray()[C:\work\flex\dmv_automation\projects\datavisualisat ion\src\mx\charts\Legend.as:666]
           at mx.charts::Legend/commitProperties()[C:\work\flex\dmv_automation\projects\datavisualisati on\src\mx\charts\Legend.as:449]
           at mx.core::UIComponent/validateProperties()[C:\autobuild\3.2.0\frameworks\projects\framewor k\src\mx\core\UIComponent.as:5807]
           at mx.managers::LayoutManager/validateProperties()[C:\autobuild\3.2.0\frameworks\projects\fr amework\src\mx\managers\LayoutManager.as:539]
           at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.2.0\frameworks\projects \framework\src\mx\managers\LayoutManager.as:659]
           at Function/http://adobe.com/AS3/2006/builtin::apply()
           at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.2.0\frameworks\projects\framew ork\src\mx\core\UIComponent.as:8628]
           at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.2.0\frameworks\projects\framewo rk\src\mx\core\UIComponent.as:8568]
      when i close adding those swfs in loop i have the same error, it looks like child apps couldn't access
      certain objects that were instantiated by another child app, so what can i do?
        • 1. Re: problem with SWFLoader
          Flex harUI Adobe Employee
          Put those classes in an RSL or module and load it into the main app domain.
          See the "shared code" module in the examples with the modules post on my
          blog.
          • 2. Re: problem with SWFLoader
            TomCreo Level 1
            i try , but when i put chart inside module, it won't render, not displays.
            • 3. Re: problem with SWFLoader
              Check out the modules presentation on my blog.  You can pre-load some
              classes (the ones that are being shared) then the sub-apps can load after
              and share those classes.  In the blog post I show how to do it for modules,
              but the technique will work for sub-apps too.
              Alex Harui
              Flex SDK Team
              Adobe System, Inc.
              http://blogs.adobe.com/aharui
              • 4. Re: problem with SWFLoader
                TomCreo Level 1
                i am using now modules as you said, but there is big problem with passing parameters using query String and read from loaderInfo, when i am loading two the same modules with diferent parameters, querry string is exactly the same, why? i have noticed that i have this problem only when i load modules using :
                var applicationDomain:ApplicationDomain = ApplicationDomain.currentDomain;
                singleModuleInfo.load(applicationDomain);
                when
                singleModuleInfo.load(); passing parameteres with querryString works fine
                but i need ues applicationDomain cos i have problem with bug in modules with IStroke in area chart
                so normal i have following error:
                cannot convert mx.graphics::Stroke@205c5d61 to mx.graphics.IStroke
                and when i use applicationDomain this problem disapeares, but now i have problem with passing query string in two the same modules, any help?
                • 5. Re: problem with SWFLoader
                  Because a module only gets loaded once, and the factory generates multiple
                  instances.  Instead of using url params, set properties on the factory'd
                  instances.
                  • 6. Re: problem with SWFLoader
                    TomCreo Level 1
                    Thanks for Your replay, any sugestion or example how to do it?
                    • 7. Re: problem with SWFLoader
                      Hopefully before you maybe loaded the subapp via
                          swfLoader1.source="subapp.swf?foo=1
                          swfLoader2.source="subapp.swf?foo=2
                      And code somewhere in the Application checked parameters.foo and set foo
                      appropriately:
                          <mx:Application initialize="checkFoo()"...
                          <mx:Script>
                              public var foo:int;
                              private function checkFoo():void
                                  foo = parameters.foo;
                      Now you just load the module once w/o parameters
                          private var modInfo:IModuleInfo = ModuleManager.getModule("module.swf");
                      And once the module is ready:
                          var module1:IMyModuleInterface = modInfo.factory.create();
                          module1.foo = 1;
                      And
                          var module2:IMyModuleInterface = modInfo.factory.create();
                          module2.foo = 2;
                      • 8. Re: problem with SWFLoader
                        TomCreo Level 1
                        I am complatyly not getting your way of thinkng, i done it another way, i have created interface and each module impelemnts it. Then when i load some module i cast them on this interface and load some function which this interface implements.
