2 Replies Latest reply on Aug 24, 2010 8:40 AM by miguel8312
    compare arraycollections
    miguel8312 Level 3
      hello guys
      im trying to compare two array collections but im having a nightmare doing it.
      here is my code so far but icat seem to bring it home. basically when i find a difference withing one array compare to the other i like to change the  value at a specific index of the collection
      var mess1:String = new String();
      var mess2:String = new String();
      //compare the two arrays and decide wether it came from this seession or the outside.
      for(var i:int = 0; i< dispArray.length; ++i){                     mess1=dispArray[i].fwchat_message
      for(var i2:int = 0; i2< sess_MessArr.length; ++i2)
                          mess2=sess_MessArr[i2];
      if(mess1!=mess2){trace(mess1 + "" + mess2 + "" + 'are not equal')}
      any help would be greatly appreciated.
      Miguel
        • 1. Re: compare arraycollections
          betheflexcoder Level 2
          If you are using an array collection,
          private function compareArrayCollections():void
                         mess1:String =dispArray.getItemAt(i) as String;
                            if( !checkInSession(mess1))
                             trace(mess1 + "" + mess2 + "" + 'are not equal';
          private function checkInSession(message:String): Boolean
               var flag:Boolean = false;
                              mess2=sess_MessArr.getItemAt(i) as String;
                    if(message == mess2)
                         flag = true;
                          break;
               return flag;
          In case of arraycollection, instead of a separate method like above to checkInSession, you can use sess_MessArr.contains(mess1) which returns boolean.
          If you are using array and not arraycollection, get the item like sess_MessArr[i]
          • 2. Re: compare arraycollections
            miguel8312 Level 3
            thanks really appreciated your help on this one!!!
            Miguel
