0 Replies Latest reply on Jul 31, 2007 10:10 AM by KevinNSWong
    Flex Builder 2 OutOfMemory Exception
    KevinNSWong
      I am having a memory problem with both Flex Builder 2 standalone and Flex Builder 2 eclipse plugin.
      I've developed a flex component library that is approximately 1.8MB (as far as the size of the project folder). Whenever I start flex builder I get the following error message found in the .metadata/.og file:
      ENTRY org.eclipse.osgi 2007-07-31 09:56:53.343
      !MESSAGE Application error
      !STACK 1
      java.lang.StackOverflowError
      at java.net.URLClassLoader$2.run(Unknown Source)
      at java.security.AccessController.doPrivileged(Native Method)
      at java.net.URLClassLoader.findResource(Unknown Source)
      etc. etc. etc.
      The only way I am able to work around this problem is to remove the entire project folder from my workbench, start flex builder 2, then copy the project folder back into eclipse. I then have to follow a few more steps (re-adding .swc files, re-establishing dependencies between projects) before I can begin work.
      I have tried modifying my flexbuilder.ini file and this does not make a difference.
      Current contents of flexbuilder.ini file (as suggested in another, similar thread):
      -vmargs
      -Xms512M
      -Xmx512M
      -XX:MinHeapFreeRatio=20
      -XX:MaxPermSize=128m
      -XX:PermSize=128m
      My computer has 2GB of RAM.
      Any suggestions?
