4 Replies Latest reply on Aug 24, 2010 4:48 AM by Ibarim
    Focus on tabNavigator instead of textInput
    Ibarim Level 1
      I've got a tab navigator with forms inside, something like this:
      <mx:TabNavigator id="tabNav" width="433" height="100%" fontSize="12" fontWeight="normal" creationPolicy="all">
           <mx:Form label="Basic" width="100%" height="100%">
           <mx:FormItem label="Surname" width="100%" height="100%">
                <mx:TextInput id="surnameInput" text="{gridPacjent.selectedItem.nazwisko}" editable="false" width="200"/>
           </mx:FormItem>
           <mx:FormItem label="Name" width="100%" height="100%">
                <mx:TextInput id="nameInput" text="{gridPacjent.selectedItem.imie}" editable="false" width="200"/>
           </mx:FormItem>
           </mx:Form>
           <mx:Form label="Advanced" width="100%" height="100%">
               <some other formItems....>
           </mx:Form>
      </mx:TabNavigator>
      then, on some button press I got this function to set focus on textInput on the first tab:
       private function newPerson():void {
               surnameInput.editable = true;
               tabNav.selectedIndex = 0;
               //I tried this
               nazwiskoInput.setFocus();
               //and this
               stage.focus = nazwiskoInput;
               //and this
               nazwiskoInput.setSelection(0,0);
      but every solution I try sets the focus on tab navigator's tab instead of a textInput control. Has anyone got any idea how to do it properly?
      The problem appears only when I'm on other tabs. For example: when the component appears on the stage then calling this fuction newPerson() works good - it sets focus on the textInput control. But when I go to any other tab and then call this function it focuses on tab navigator.
        • 1. Re: Focus on tabNavigator instead of textInput
          BhaskerChari Level 4
          Hi lbarim,
          Checkout this example below...It works even if you navigate to another tab and returns to the original tab...
          Actually I think the problem is coming with the property that you set editable="false" on TextInput...
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
          <mx:Script>
            <![CDATA[
                      surnameInput.setFocus();
                      //This below line is required only if you want to put the cursor at the first position of textinput
                      //surnameInput.setSelection(0,0);
          </mx:Script>
          <mx:Button label="Set Focus" click="newPerson()"/>
                    <mx:TextInput id="surnameInput" text=""  width="200"/>
               </mx:FormItem>
                    <mx:TextInput id="nameInput" text="" width="200"/>
               </mx:FormItem>
               </mx:Form>
               </mx:Form>
          </mx:TabNavigator>
          </mx:Application>
          Bhasker
          • 2. Re: Focus on tabNavigator instead of textInput
            Ibarim Level 1
            ****, I posted wrong names in my original post. The function is actually doing what you adviced:
            I was using 'surnameInput.setFocus();' and 'stage.focus=surnameInput', but they don't work - they set focus on the tab navigator instead of textInput
            I also removed the 'editable=false' parameter but it didn't help either.
            Thanks for help though.
            • 3. Re: Focus on tabNavigator instead of textInput
              Hi lbarim,
              Have you tested the sample code that I have posted in my previous post...???
              I could see no problem in that...and I could see the focus being set in both cases..
              Are you using Flex3 or FlashBuilder4..??
              Bhasker
              • 4. Re: Focus on tabNavigator instead of textInput
                Ibarim Level 1
                I tested Your solution and it works. But my still doesn't
                I wonder where the difference might be...
                - I'm doing a full-screen Air app. not a browser app., but it has nothing to do, I tested your proposition as an Air app. and it worked
                - my tabNavigator is inside HBox, which is inside a VBox, which is inside a Panel. But it shouldn't have any consequences on focus behaviour
                - my textInput 'text' property has a bindable data: text="{someGrid.someItem.someField}", but it shouldn't spoil anything either
                - I got 3 tabs in my tabNavigator, but it has no influence on focus
                I don't know what else might be wrong. I'm working on Flex 3.
