1 Reply Latest reply on Aug 24, 2010 11:59 PM by Shongrunden
    How to get the value of a slider immediately after action is performed in SDK 4.0?
    pgpradeep Level 1
      I am using ActionScript to set the value of a VSlider/HSlider.
      I want to immediately cross-check whther the slider value has changed.
      For this, I am immediately (as soon as I set the slider value through code) checking VSlider.value or HSlider.value.
      But this is not giving me the values that have been set.
      Is there any other way that I can get the values as soon as I exceute slider change?
      Pradeep.
        • 1. Re: How to get the value of a slider immediately after action is performed in SDK 4.0?
          Shongrunden Adobe Employee
          Does listening for the change or valueCommit events get you what you need?
          For example:
          <s:Application
              xmlns:fx="http://ns.adobe.com/mxml/2009">
              <fx:Script>
                  <![CDATA[
                      import mx.events.FlexEvent;
                      // valueCommit gets fired any time the value of the slider changes
                      private function mySlider_valueCommitHandler(event:FlexEvent):void {
                          trace("valueCommit", event.target.value);
                      // change gets fired only when the slider is changed via the UI
                      private function mySlider_changeHandler(event:Event):void {
                          trace("change", event.target.value);
              </fx:Script>
              <!-- interacting with this will fire both valueCommit and change events -->
              <s:HSlider id="mySlider" valueCommit="mySlider_valueCommitHandler(event)" change="mySlider_changeHandler(event)" />
              <!-- clicking this will only fire valueCommit events -->
              <s:Button label="programmatically change" x="200" click="mySlider.value += 1" />
          </s:Application>
