6 Replies Latest reply on Aug 24, 2010 10:03 AM by kglad
    Unable to import xml into my CS4 project
    volterony22
      Hi folks,
      I am trying to embed a 3rd party flash component into my current flash project.  As a stand alone, the component works fine but when I try and import the xml file for the component into my current flash project library, the message I get:
      " one or more files were not imported because there were problems reading them"!!!
      I have tried importing the xml file into another dummy cs4 project on another machine and again no success, so I believe there are elements within the xml file that will not work with cs4.  Below is the xml file code.  I would appreciate if anyone can spot anything wrong with this file as to why it wont import into flash.  Even try and import it yourself and see what I mean.
      Hope someone can help.
      Regards
      Volterony22
      <?xml version="1.0" encoding="UTF-8"?>
      There are 9 positions available :
      1. TL: top-left
      2. TC: top-center
      3. TR: top-right
      4. ML: middle-left
      5. MC: middle-center
      6. MR: middle-right
      7. BL: bottom-left
      8. BC: bottom-center
      9. BR: bottom-right
      If you set randomizePositions to true, it will overwrite the values you pass for each item
      startZoom: the zoom value to start with
      endZoon: the zoom value to end with
      transitionTime: the time for the slide to reach from property A to property B
      slideShowTime: the time the slide stays on screen
      disablePauseButton: it needs to be set to true if you want to have links on the slideshow
      NOTE: The transition time must be higher than the slideshow time for each item! (make sure the difference is at least alphaTime value)
        The reason is so the zoom effect doesn't end before the transition does.
      <kenburns width = "1000" height = "348"
      backgroundColor = "0x000000"
      backgroundTransparency = "0"
      startWith = "1"
      randomSlideshow = "true"
      loop = "true"
      randomizeImagePosition = "false"
      alphaTime = "2"
      textX = "10"
      textY = "10"
      overColor = "0x000000"
      overAlpha = "20"
      disablePauseButton = "true">
      <item>
      <title><![CDATA[<font size="16" color="#ffffff">Sand beach in the morning</font>]]></title>
      <path>content/images/image1.jpg</path>
      <link></link>
      <target>_blank</target>
      <transitionTime>12</transitionTime>
      <slideShowTime>8</slideShowTime>
      <startZoom>80</startZoom>
      <endZoom>100</endZoom>
      <startPosition>MC</startPosition>
      <endPosition>MC</endPosition>
      </item>
      <item>
      <title></title>
      <path>content/images/image2.jpg</path>
      <link></link>
      <transitionTime>25</transitionTime>
      <slideShowTime>22</slideShowTime>
      <startZoom>100</startZoom>
      <endZoom>55</endZoom>
      </item>
      <item>
      <title><![CDATA[<font size="18" color="#ffffff">Waves and wind</font>]]></title>
      <path>content/images/image3.jpg</path>
      <link></link>
      <transitionTime>27</transitionTime>
      <slideShowTime>20</slideShowTime>
      <startZoom>70</startZoom>
      <startPosition>TC</startPosition>
      <endPosition>BC</endPosition>
      </item>
      <item>
      <title><![CDATA[<font size="18" color="#224F91">No words needed..</font>]]></title>
      <path>content/images/image4.jpg</path>
      <link></link>
      <slideShowTime>9</slideShowTime>
      <endZoom>80</endZoom>
      <startPosition>BL</startPosition>
      <endPosition>TR</endPosition>
      </item>
      <item>
      <title></title>
      <path>content/images/image5.jpg</path>
      <link></link>
      <transitionTime>35</transitionTime>
      <slideShowTime>32</slideShowTime>
      <startZoom>55</startZoom>
      <startPosition>BC</startPosition>
      <endPosition>TC</endPosition>
      </item>
      <item>
      <title></title>
      <path>content/images/image6.jpg</path>
      <link>http://www.flabell.com</link>
      <transitionTime>10</transitionTime>
      <startZoom>40</startZoom>
      <endZoom>35</endZoom>
      <startPosition>ML</startPosition>
      <endPosition>MR</endPosition>
      </item>
      <item>
      <title></title>
      <path>content/images/image7.jpg</path>
      <link></link>
      <transitionTime>20</transitionTime>
      <startPosition>MR</startPosition>
      <endPosition>ML</endPosition>
      </item>
      <item>
      <title></title>
      <link></link>
      <startZoom>50</startZoom>
      <endZoom>60</endZoom>
      </item>
      </kenburns>
