4 Replies Latest reply on Aug 24, 2010 12:40 PM by thebouv
    access array in arraycollection and add item to the end of array
    miguel8312 Level 3
      for
      "login_user":"XXX"},i);
      //mess2=sess_MessArr[i2];
      //mess1=dispArray[i2].fwchat_message
      //searchArray(mess2);}
      (var i:int = 0; i< dispArray.length; ++i){
      dispArray[i].
      dispArray.addItemAt({
      I have this code to try to acess the values of the array in the  arraycollection but it does not work it actually creates a value to the end of the arraycollection. can anyone tell me what im doing wrong i basically whant to modifys the individual arrays in the arraycollection and add Login_user
        • 1. Re: access array in arraycollection and add item to the end of array
          miguel8312 Level 3
          sorry everyone my code got messed up above. here is the code again
          for
          dispArray[i].
          "login_user":"Miguel83"},i);
          • 2. Re: access array in arraycollection and add item to the end of array
            thebouv Level 2
            So, I'm assuming your ArrayCollection is holding an array of objects, like so:
            public var myAC:ArrayCollection = new ArrayCollection([{first:"bob",last:"smith"},{first:"jim",last:"jones"},{first:"mary",last:"allen"}]);
            And you're trying to add in a new property of login_user to each one, right?
            for each (var obj:Object in myAC) {
                 obj.login_user = obj.first + "83";
            Each person would then have first, last and login_user properties.  In my little example above, everyone's login_user would be set to their first name + number 83, so you'd adjust accordingly for  your purposes.
            That's the easy way (for each rocks for just such a situation).  However, if you want to stick to the iterative approach you posted, you could try this:
            for (var i:int = 0; i < myAC.length; i++) {
                 myAC.getItemAt(i).login_user = myAC.getItemAt(i).first + "83";
            I think the for each syntax is clearer, but either way works as I think you wanted.
            • 3. Re: access array in arraycollection and add item to the end of array
              miguel8312 Level 3
              dude!!! you are a genius. i neve seem this syntax before with the obj.first + "83"
              I modify your code slightly and it worked like a charm.
              here is what i went with.
              THANK you!!!!
              for each
              (var obj:Object in dispArray) {
              obj.login_user = _user;
              • 4. Re: access array in arraycollection and add item to the end of array
                thebouv Level 2
                Glad it worked.  My example was just adding "83" to the end of the first name since I didn't really know your login_name scheme or how you came up with them.
                Have fun programming!
