3 Replies Latest reply on Aug 24, 2010 10:07 AM by the_wine_snob
    Full Unedited export
      I have just returned from holiday and want to play all my clips in the sequence taken at full quality.
      What is the quickest way to export my media for viewing.  Its 1080-25
      I was hoping it wouldnt need to go through the 8 hours encoding just pin all clips together and save as one file.
      Can it be done ?
        • 1. Re: Full Unedited export
          That depends on your INPUT codec and your EXPORT codec
          Since you don't provide information on either... no way to answer
          • 2. Re: Full Unedited export
            carlosalt Level 1
            its .mov from my canon dslr.
            so instead lots of individual mov clips just one big mov
            • 3. Re: Full Unedited export
              the_wine_snob Level 9
              Probably the easiest way to do this is to Import the MOV footage, and then drag one to the New Icon, to create a Sequence that matches that footage. Drag the rest to that Sequence, and tighten things up, as required.
              Then, the Export Settings will depend on how you wish to "deliver" the file. If BD, then use Adobe Dynamic Link to Import it into Encore, and do any navigation that you might want. Burn to BD and use a BD player.
              If you wish to do other for delivery, let us know, and someone can give you the best Export Settings.
