0 Replies Latest reply on Aug 24, 2010 10:50 AM by ysetko
    using WSDL generated classes
    ysetko
      Hello,
      I have a bunch of classes created by FlashBuilder4 from a WSDL, but I am having troubles using some of them.
      For example, here is a part of a Web Service request generated by SoapUI from the same WSDL:
      <ns:DepartureDateTime WindowBefore="?" WindowAfter="?" CrossDateAllowedIndicator="?">?</ns:DepartureDateTime>
      On Flex generated class I can see all XML tag attributes such us "WindowBefore", "WindowAfter" and "CrossDateAllowedIndicator" represented as variables with Get and Set methods:
           * properties
          private var _internal_WindowBefore : int;
          private var _internal_WindowAfter : int;
          private var _internal_CrossDateAllowedIndicator : Boolean;
      So I can assign values to those attributres:
                  var dateTime:DateTime_type = new DateTime_type();
                  dateTime.OutBound = new TravelDateTimeType();
                  dateTime.OutBound.DepartureDateTime = new TimeInstantType();
                  dateTime.OutBound.DepartureDateTime.WindowAfter = "P1970Y1M1DT7H";
                  dateTime.OutBound.DepartureDateTime.CrossDateAllowedIndicator = false;
                  dateTime.OutBound.DepartureDateTime.???
      However there is nothing on "dateTime.OutBound.DepartureDateTime" that I could find to assign the actual XML tag value (2010-02-18T06:43:00):
      <DepartureDateTime WindowAfter="P1970Y1M1DT7H">2010-02-18T06:43:00</DepartureDateTime>
      Am I missing something?
      How can I assign that "2010-02-18T06:43:00" value to the WebService Request instance?
      Apreciate your help.
      George
