4 Replies Latest reply on Aug 24, 2010 2:08 PM by ksumwalt
    File variable
    ksumwalt Level 1
      I am looking to define a temporary variable in an Acrobat Form, which is specific to the file only, but can't find anything.  I am looking for something similar to a Global variable, but not available across documents.  I could create a text field that is hidden and does not print, but I was hoping for something cleaner.  Is there a form level variable?
      Regards,
      Karl
        • 1. Re: File variable
          George_Johnson MVP & Adobe Community Professional
          If you create a document-level JavaScript and declare a variable (outside of a function definition), it will have document-level scope.
          var mydocvar = "Jimmy Buffett";
          • 2. Re: File variable
            ksumwalt Level 1
            OK, so I have tried the following to declare a variable outside of a function definition in the JavaScript Functions dialog that opens with the  Advanced->Document Processing->Document Javascripts menu option:
            Define a name, Karl, and put the declaration in front of the function:
            var formVariable = "";
            function Karl()
            I have also just put the decloration in, then removed the () generated:
            Put var formVariable = "" in for the Script Name, get
            function var formVariable = ""()
            Change it to:
            or:
            And none of this work.  The variable does not seem to be defined when I try to display it with:
            app.alert(formVariable, 1, 2);
            I am sure I am missing something, so how do I define the variable outside a function?  (Note, the function Karl() would be used to reset the variable, and other things as well, I took the rest out for clarity.
            • 3. Re: File variable
              The last variable declaration you showed is correct. But note that you initialized the variable to a zero-length string, so your app.alert will not show anything.
              How about this:
              var formVariable = "Hello";
              and then, place the following code in the MouseUp event of a button:
              app.alert(formVariable, 2, 1);
              and press the button.
              Does that work?
              BTW, variables declared within a function are local to that function. So to reset the variable, the function would look like:
              function Karl() {
                  formVariable = "";
              • 4. Re: File variable
                ksumwalt Level 1
                It seems there was another error in code, where I put a ; at the end of the closing parenthesis for an if statement:
                     if (true);
                It didn't work, so I thought the variable was not being saved.  I fixed this just before your last response.
                Thank you for the help!
                Karl
