9 Replies Latest reply on Sep 8, 2010 10:06 AM by Chris|Cousins
    Crash (freeze) when scrubbing with audio
    Chris|Cousins Level 1
      Hi - I'm getting frequent (say, every 10 minutes) crashes when scrubbing through a comp while holding down the Command key to preview audio, using AECS5 on a MacPro with OSX10.6. I've tried .aif, .wav and .mov fomats for the audio track with as many compressors as I can think of, I've tried using the built-in speakers and the front & rear line-out. This particular audio track is around 6mins long, there's only one track per comp and no keyframes on it - but I've had the problem with other audio files too.
      Any clues? I've changed the audio hardware prefs to a range of values, 64-1024 buffer size and different audio outputs.
      The crash is a freeze, not a quit, so no crash report comes up, although the OSX reporter does recognise the crash, here's the (cut down) info. Thanks for any help, it's driving me up the wall...
      Date/Time:       2010-08-25 00:01:59 +0100
      OS Version:      10.6.4 (Build 10F569)
      Architecture:    x86_64
      Report Version:  6
      Command:         After Effects
      Path:            /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
      Version:         10.0 (10.0)
      Parent:          launchd [115]
      PID:             991
      Event:           hang
      Duration:        12.32s (sampling started after 2 seconds)
      Steps:           103 (100ms sampling interval)
      Pageins:         0
      Pageouts:        0
      Process:         After Effects [991]
      UID:             501
      Process:         Adobe QT32 Server [1000]
      Path:            /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Adobe QT32 Server.app/Contents/MacOS/Adobe QT32 Server
      UID:             501
      Process:         AdobeCrashDaemon [993]
      Path:            /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/Resources/AdobeCrashD aemon.app/Contents/MacOS/AdobeCrashDaemon
      UID:             501
      Model: MacPro4,1, BootROM MP41.0081.B07, 8 processors, Quad-Core Intel Xeon, 2.66 GHz, 16 GB, SMC 1.39f5
      Graphics: ATI Radeon HD 4870, ATI Radeon HD 4870, PCIe, 512 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.91.27)
      Bluetooth: Version 2.3.3f8, 2 service, 19 devices, 1 incoming serial ports
      Network Service: Ethernet 2, Ethernet, en1
      PCI Card: ATI Radeon HD 4870, Display, Slot-1
      Serial ATA Device: HL-DT-ST DVD-RW GH41N
      Serial ATA Device: WDC WD6400AAKS-41H2B0, 596.17 GB
      Serial ATA Device: WDC WD1001FALS-00J7B0, 931.51 GB
      USB Device: Pro9000II series, 0x04a9  (Canon Inc.), 0x10cf, 0xfd300000
      USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfd100000
      USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0221, 0xfd120000
      USB Device: PTZ-930, 0x056a  (WACOM Co., Ltd.), 0x00b2, 0x1a200000
      USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0x5a110000
      FireWire Device: built-in_hub, Up to 800 Mb/sec
      FireWire Device: unknown_device, Unknown
        • 1. Re: Crash (freeze) when scrubbing with audio
          A bit more info, while I'm waiting for yet another restart -- the freezes seem to be when I leave the main AE comp, go and do something in a sub-comp then come back to the main comp. If I stick to the main comp window and do everything in there then AE seems to behave better, I can sometimes get, oooh, 30mins of work done before crashing.
          I've put the full OSX activity sample here: here.
          In the console I can see a lot of these:
          25/08/2010 01:54:35 WDDriveManagerStatusMenu[149] *** attempt to pop an unknown autorelease pool (0x819600)
          Yup, that's 2am, and yup my deadline is tomorrow morning... Thanks for any assistance.
          • 2. Re: Crash (freeze) when scrubbing with audio
            TimeRemapper Level 4
            Do you have multiple monitors running? If so, albeit a pain, try working in only one. Also, try disabling OpenGL if you have it enabled. If you're viewing the waveforms for the audio files you're working with, is there any way for you to feasibly work without expaning the waveform? If not, can you zoom into your timeline so as to not create the need to draw large time blocks of the waveform? Do you have the most recent Wacom drivers installed? And, are you working off of local drives? on a network?
            Everything else aside, have you tried recreating the prefs?
            • 3. Re: Crash (freeze) when scrubbing with audio
              Thanks TimeRemapper - lots of questions.
              Do you have multiple monitors running? Just the one.
              Also, try disabling OpenGL if you have it enabled. Off, force of habit...
              If you're viewing the waveforms for the audio files you're working with... The audio file is folded, I don't need to see the waveform
              Do you have the most recent Wacom drivers installed? I've got the most recent RC.
              And, are you working off of local drives? Local drives - it's reading from a RAID-0
              Checking the console from earlier this evening, I've got pages and pages of these:
              25/08/2010 00:48:53 After Effects[1212] *** __NSAutoreleaseNoPool(): Object 0x15503efa0 of class NSCFArray autoreleased with no pool in place - just leaking
              25/08/2010 00:48:53 After Effects[1212] *** __NSAutoreleaseNoPool(): Object 0x110fc95f0 of class NSCFArray autoreleased with no pool in place - just leaking
              25/08/2010 00:48:53 After Effects[1212] *** __NSAutoreleaseNoPool(): Object 0x10c24d5d0 of class __NSArray0 autoreleased with no pool in place - just leaking
              25/08/2010 00:48:53 After Effects[1212] *** __NSAutoreleaseNoPool(): Object 0x15503f4d0 of class NSCFArray autoreleased with no pool in place - just leaking
              25/08/2010 00:02:14 aeselflink[1006] *** __NSAutoreleaseNoPool(): Object 0x10e30b8d0 of class NSCFArray autoreleased with no pool in place - just leaking
              25/08/2010 00:02:14 aeselflink[1005] *** __NSAutoreleaseNoPool(): Object 0x1316e6920 of class NSCFArray autoreleased with no pool in place - just leaking
              25/08/2010 00:02:14 aeselflink[1003] *** __NSAutoreleaseNoPool(): Object 0x128b0b3f0 of class NSCFArray autoreleased with no pool in place - just leaking
              25/08/2010 00:02:14 aeselflink[1007] *** __NSAutoreleaseNoPool(): Object 0x10c669660 of class NSCFArray autoreleased with no pool in place - just leaking
              25/08/2010 00:02:14 aeselflink[1004] *** __NSAutoreleaseNoPool(): Object 0x132d74730 of class NSCFArray autoreleased with no pool in place - just leaking
              Fun.
              • 4. Re: Crash (freeze) when scrubbing with audio
                Is there any chance you can move the project to a different drive (not on that RAID - even the OS drive for testing purposes) and see if you still run into the problem? Do you have multi-processing disabled or enabled?
                • 5. Re: Crash (freeze) when scrubbing with audio
                  Is there any chance you can move the project to a different drive (not on that RAID - even the OS drive for testing purposes) and see if you still run into the problem? Well it's big comp but I've tried an archive project off a firewire drive, that stuttered and then crashed in the same way.
                  Do you have multi-processing disabled or enabled? Enabled usually, just tried without and the crash happened as usual.
                  Here's a not very informative video of the problem. Thanks for trying...
                  • 6. Re: Crash (freeze) when scrubbing with audio
                    Dang. Well, I'm running short of ideas.
                    I'm figuring that the video you posted was for demo purposes only, and as such, this may not be an issue, but do you have a file suffix on your audio file? It looks like the one in your project window has no suffix ( .wav).
                    • 7. Re: Crash (freeze) when scrubbing with audio
                      Just an update in case anyone's having the same issues - try cleaning out your Library/Quicktime/ folder, especially 3rd party codecs - it might have been down to a (video) codec called x264, I've removed that and it's a bit too soon to be sure, but seem to be having a better time.
                      • 8. Re: Crash (freeze) when scrubbing with audio
                        Todd_Kopriva Level 8
                        The After Effects CS5 (10.0.1) update is available:
                        http://bit.ly/9ex5Cf
                        This update should address this issue. After you've installed the update, please let us know whether it works for you.
                        If you have any problems with the update, or if you have bugs to report  after you've installed the update, please let us know through the usual  channels:
                        http://bit.ly/93d6NF
                        • 9. Re: Crash (freeze) when scrubbing with audio
                          Been working in 10.01 all day (with the x264 codec back in, not sure if that was the issue) - no audio crashes today, all working nicely - thanks for getting this sorted!
                          Cheers - Chris
