4 Replies Latest reply on Aug 1, 2007 5:47 AM by emmim44
    Nuts
    emmim44 Level 1
      Hi all. The logic I am trying to implement is not working properly.Could you check my code ? It dropped me nut..
        • 1. Re: Nuts
          Level 7
          please do describe your attempted logic in plain English - not many
          people have the time to go through all that code of yours and try to
          FIGURE OUT your logic and then figure out what's wrong with it... well,
          at least i don;t have that much time...
          Azadi Saryev
          Sabai-dee.com
          http://www.sabai-dee.com
          • 2. Re: Nuts
            emmim44 Level 1
            That is not helpful. I couldnt figure out that is why I am posting here.
            • 3. Re: Nuts
              cf_dev2 Level 1
              Seriously neither is posting 100+ lines of code with a note that "its not working properly". How do you expect people to know what the code IS suppposed to be doing unless you give a description of the desired results and the problem? Put a little effort into it.
              • 4. Re: Nuts
                emmim44 Level 1
                I assume all of you as a genius. :D
                It fixed..
                <cfset q = snum1 - 1>
                <cfif s1.msnum eq 2>
                <cfquery name="upt2" dataSource="#FormVector#">
                update genbid_login1 set snum = snum -1
                where status = 'A' and role = 'LT'
                </cfquery>
                <cfelseif q lt s1.mxsnum and snum1 gte 1>
                where snum > #q# and status = 'A' and role = 'LT'
                </cfquery>
                <cfelseif snum1 eq s1.mxsnum>
                where snum = #s1.mxsnum# and status = 'A' and role = 'LT'
                </cfquery>
                </cfif>
