2 Replies Latest reply on Aug 25, 2010 12:15 AM by hdave123
    Add full screen button to app?
    hdave123
      Anyone know the action script methods I could use in a click handler to have an application goto full screen?
        • 2. Re: Add full screen button to app?
          BhaskerChari Level 4
          Hi Hdave,
          Check out the below code...
          <!-- http://blog.flexexamples.com/2007/08/07/creating-full-screen-flex-applications/ -->
          <mx:Application
          name="FullScreen_test"
          xmlns:mx="
          http://www.adobe.com/2006/mxml"
          layout="
          vertical"
          applicationComplete="init(event)"
          <mx:Script>
          <![CDATA[
          import flash.display.StageDisplayState;
          private function init(evt:Event):void {
          /* Set up full screen handler. */
          Application.application.stage.addEventListener(FullScreenEvent.FULL_SCREEN, fullScreenHandler);
          dispState = Application.application.stage.displayState;
          private function fullScreenHandler(evt:FullScreenEvent):void {
          dispState = Application.application.stage.displayState +
          " (fullScreen=" + evt.fullScreen.toString() + ")";
          if (evt.fullScreen) {
          /* Do something specific here if we switched to full screen mode. */
          else {
          /* Do something specific here if we switched to normal mode. */
          private function toggleFullScreen():void {
          try {
          switch (Application.application.stage.displayState) {
          case StageDisplayState.FULL_SCREEN:
          /* If already in full screen mode, switch to normal mode. */
          Application.application.stage.displayState = StageDisplayState.NORMAL;
          break;
          default:
          /* If not in full screen mode, switch to full screen mode. */
          Application.application.stage.displayState = StageDisplayState.FULL_SCREEN;
          break;
          catch (err:SecurityError) {
          // ignore
          </mx:Script>
          <mx:String id="dispState" />
          <mx:Label text="width={Application.application.width}" />
          <mx:Label text="height={Application.application.height}" />
          <mx:Label text="displayState={dispState}" />
          <mx:Button label="Toggle fullscreen" click="toggleFullScreen()" />
          </mx:Application>
          Bhasker
