1 Reply Latest reply on Aug 25, 2010 12:50 AM by Peter Grainge
    Change case of folder names
    Anant_
      I have a huge collection of folders in my RoboHelp project (I us
      e version 8). All the folders are named in upper case. We have decided to
      follow a standard of naming all the folders in lower case. Whenever I try to change the folder names in lower case, they automatically get converted to upper case. What would be the easiest and quickest solution to implement this change?
        • 1. Re: Change case of folder names
          Unfortunately a bug crept back into RH8. You will have to use the old trick as below. Add a character to the uppercase filename and then remove it change the case at the same time.
          MYFILENAME
          1MYFILENAME
          myfilename
          You can force the output to be lowercase in the wizard but if you are working with merged help or external links, it would be better to change things in the source.
          @petergrainge
