6 Replies Latest reply on Aug 25, 2010 9:14 AM by Kasyan Servetsky
    Server rename & links (CS5 & 10.6)
    jamesv1ncent
      Our existing server (Windows 2003) will be decommissioned shortly and replaced with a newer storage server (Windows 2008). From past experience I know this will wreak havoc with our designers and as such we have been liaising with them. Our designers run OSX 10.6 with a mixture of CS3/CS4/CS5.
      The bad news is we don't seem to be able to find a sure fire way of preventing any linking problems! Can you guys help?
      At present for our lead designer, the links in a .INDD file look like;
      /Volume/DOMAIN;SVR01/Share/Folder/To/Images/image1.jpg
      I don't know why the links look like this... but, ultimately, what will change is the server name, so from SVR01 to SVR02 (for example)
      Can I modify the links of all our INDD files easily to reflect this?
      Our designers don't package their documents.
        • 1. Re: Server rename & links (CS5 & 10.6)
          Marijan Tompa [tomaxxi] Level 4
          Hey!
          I think Kasyan Servetsky posted script here on forum. Try searching forum, or take look at his scripts collection: http://www.kasyan.ho.com.ua/my_scripts.html
          tomaxxi
          http://indisnip.wordpress.com/
          • 2. Re: Server rename & links (CS5 & 10.6)
            jamesv1ncent Level 1
            I've tried a few of the scripts, but they don't seem to play with CS5, unless I'm doing something wrong....
            • 3. Re: Server rename & links (CS5 & 10.6)
              Kasyan Servetsky Level 5
              I haven't posted some of my new scripts on my site yet, but here, on InDesign forum, I posted a script that might be of interest to you.
              Warning! I haven't tested it with CS5 — only with CS3/4.
              Kasyan
              • 4. Re: Server rename & links (CS5 & 10.6)
                Kasyan, that was one of the scripts I tested yesterday, but it didn't seem to work
                • 5. Re: Server rename & links (CS5 & 10.6)
                  Try this: Create a folder "Version 6.0 Scripts" in your User Scripts folder, and put Kasyan's script in there. (This special folder name instructs ID to relax a little on the error messages.)
                  • 6. Re: Server rename & links (CS5 & 10.6)
                    I just tested it on CS5 (7.0.1 Mac) and it works for me. I am not lucky in that our admin haven't changed our server names for years, so I don't have such a problem -- even when I open a file created on Windows on Mac, or vice versa, InDesign silently updates all the paths, it finds them even if a folder name changed.
                    So I made a little test:
                    1. Created an ID document on Windows (CS3)
                    Paths of links looks like so:
                    2. Deleted "images" folder -- otherwise ID finds them
                    3. Opened, converted and resaved the document in CS5 -- all links are missing now
                    4. Restored the deleted folder in Links panel paths look like so:
                    Macintosh HD:10.44.54.70:Test:images:foldername:subfoldername:imagefile.jpg
                    (ID tried to find missing links and screwed paths up)
                    5. I manually relinked a link to see a correct path -- it looks like this:
                    6. Reverted the document.
                    7. Run the script with parameters on the sceengrab -- all links were restored.
                    Note: Preferences > File handling > Preserve image dimensions when relinking should be checked on.
                    As far as I am concerned, I don't have this problem -- but often see on forums that other people encounter it -- that's why I wrote this script (and its numerous variations). But I have no idea how useful/less it is, and if it works for anybody except me.
                    Anyway, if you want me to continue developing it, I need more detailed input, sample files, screengrabs, etc -- just saying that it doesn't work is not enough for me to figure out the problem.
                    Regards,
                    Kasyan
                    P.S. To quickly get path of a link in CS4/5, right click in Links panel and choose "Copy Platform Style Path"
