3 Replies Latest reply on Aug 26, 2010 12:02 PM by ilssac
    CF redirect
    Phnoefniex
      Hello,
      my webserver data are as follows:
      ColdFusion 5 (is there a particular hotfix you are looking for)?
      Windows Server 2003
      IIS 6.1.
      I would like to do a redirect.
      Specification:
      For the URL field:
      1. If a user enters XXXX.com the user will be pointed to:
      http://XXXX.com/MainPath/Main.html
      2. If a user enters www.XXXX.com the user will be pointed to:
      http://www.XXXX.com/MainPath/Main.html
      3. If a user enters XXXX.com/name1 the user will be pointed to http://XXXX.com/Path1
      4. If a user enters XXX.com/name2 the user will be pointed to http://XXXX.com/Path2
      5. If a user enters XXX.com/name3 the user will be pointed to http://XXXX.com/Path3
      I am using this code:
      <!--- Default locations --->
      <CFIF server_name IS "www.XXXX.com" OR server_name IS "XXXX.com">
      <CFLOCATION url="MainPath/Main.html">
      <!---  For XXXX.com/name1 --->
      <CFELSEIF CompareNoCase(cgi.server_name, "XXXX.com") EQ 0 AND CompareNoCase(ListGetAt(cgi.path_info, 1, "/"),"name1") EQ 0>
      <CFLOCATION url=" http://XXXX.com/Path1">
      <!---  For XXXX.com/korrosion point to Io00Korro01.cfm --->
      <CFELSEIF CompareNoCase(cgi.server_name, "XXXX.com") EQ 0 AND CompareNoCase(ListGetAt(cgi.path_info, 1, "/")," name2") EQ 0>
      <CFLOCATION url=" http://XXXX.com/Path2">
      <!---  For XXXX.com/cell point to CellCycle01.cfm --->
      <CFELSEIF CompareNoCase(cgi.server_name, "XXXX.com") EQ 0 AND CompareNoCase(ListGetAt(cgi.path_info, 1, "/")," name3") EQ 0>
      <CFLOCATION url=" http://XXXX.com/Path3">
      </CFIF>
      Specification 1 and 2 above work well with <!--- Default locations --->
      But the rest of the code won't do the desired redirects of specification 3 to 5.
      Help would be appreciated.
      Phnoefniex
        • 1. Re: CF redirect
          Dan Bracuk Level 5
          Comment out the cflocation tags so you can look at your data.  Then do this sort of thing.
          <cfif something>
          yes
          <cfelse>
          no
          <cfdump var="#the_variables_you_were_looking_at#">
          closing tags.
          adjusted for your own code of course.
          At first glance, it looks like you overengineered the whole thing.
          • 2. Re: CF redirect
            Phnoefniex Level 1
            Hello,
            Not sure how to get <cfdump> to work. So I did a test.
            I have default.cfm under the root directory.
            It only contains this line:
            <cfdump var="#URL#">
            If I enter XXXX.com into the browser URL it will just display a blank page. How can I get the dump to display in the browser?
            Thanks, Phnoefniex
            • 3. Re: CF redirect
              ilssac Level 5
              Are you sure that default.cfm is automatically servers by your web server.  That file is not a common automatic file.  ColdFusion usually only configures index.cfm to be automatically serverd if no specific file is requested.
              Have you tried XXXX.com/default.cfm  do you see the dump display then?  Which, of course, is going to be empty becuase you have no url parameters.  xxxx.com/default.cfm?test=foobar will show some data in the dump.
