2 Replies Latest reply on Aug 25, 2010 10:07 PM by BhaskerChari
    using a variable to refer to an object's ID
    aklyman Level 1
      Is there a way to replace “comboBox1” in the following line of script code with a variable which contains the text “comboBox1”?
           comboBox1.dataProvider = dataArray;
      I was thinking something like this, but of course this doesn’t work---doesn't like the nameArray[i] before the dataProvider:
      function setProvider():void{
      var tempArray = [“temporary content”];
      var nameArray:Array = [“comboBox1” ,“comboBox2”,“comboBox2”];
      for (i =0, i ; nameArray.length; i++){
      nameArray[i].dataProvider = tempArray;
      <mx:ComboBox id="comboBox1"/>
      <mx:ComboBox id="comboBox2"/>
      <mx:ComboBox id="comboBox3"/>
      Thanks All
        • 1. Re: using a variable to refer to an object's ID
          GordonSmith Level 4
          You can exploit the fact that you can look up any property on any object by name, using obj[prop] notation. Applied to this case, it means that comboBox1 is the same as this["comboBox1"].
          Gordon Smith
          Adobe Flex SDK Team
          • 2. Re: using a variable to refer to an object's ID
            BhaskerChari Level 4
            Hi inanealex2010,
            You can use the following approach...
            //Use this line if you are placing the ComboBoxes directly in the root tag of your component
            ComboBox(this.getChildByName(nameArray[i]) ).dataProvider = tempArray;
            //Use this line if you are placing the ComboBoxes in any container say like canvas, Vbox or HBox
            ComboBox(containerId.getChildByName(nameArray[i]) ).dataProvider = tempArray;
            Bhasker
