1. Re: Error occurs when burning to BD-R DL disc in Encore
Ann Bens Aug 26, 2010 7:55 AM (in response to ANTHONY THOMAS)Latest firmware installed?
2. Re: Error occurs when burning to BD-R DL disc in Encore
Giorgio1957 Aug 27, 2010 9:18 AM (in response to Ann Bens)Is the disc OK?
Have you tried with another one?
I know, this will squander your patrimony!!!!!!!!!!!
Sometimes this depends by disc-burner, I had a Pioneer that loved TDK as deeply hated Sony.
Now, I have two LGs that "eat" everything without difficulties
Ciao
Giorgio
3. Re: Error occurs when burning to BD-R DL disc in Encore
ANTHONY THOMAS Aug 27, 2010 2:50 PM (in response to ANTHONY THOMAS)Well the SONY discs do fine and the firm ware is upto date. I have noticed that the Verbatim media says 6X and my bluray writes 8x. I have a
LG Super Multi BLUE BH08. I am using a internal PCIE card to run it however and the system doesn't call it a BH08LS20 when it is plugged in here but a SATA HL-DT-STBD-RE B SCSI CDROM DEVICE. Maybe I will switch inputs and see what happens.
4. Re: Error occurs when burning to BD-R DL disc in Encore
John T Smith Aug 27, 2010 3:47 PM (in response to ANTHONY THOMAS)>Verbatim media says 6X and my bluray writes 8x
Well, my guess would be that the speed difference of 6x-vs-8x is the problem
5. Re: Error occurs when burning to BD-R DL disc in Encore
poofyboy Jun 22, 2011 8:06 PM (in response to John T Smith)I get the exact same error with BD-R discs on a Pioneer and the write speed option is not available. Encore 5.0.0.508 on Windows 7 64-bit.
6. Re: Error occurs when burning to BD-R DL disc in Encore
ram8kumar Jun 22, 2011 8:25 PM (in response to ANTHONY THOMAS)I hope these posts might be of interest here. This might be a case of Bad Media.
http://forums.adobe.com/thread/867440?tstart=0
http://forums.adobe.com/thread/866831?tstart=0
Ramesh.
7. Re: Error occurs when burning to BD-R DL disc in Encore
John T Smith Jun 22, 2011 9:17 PM (in response to ANTHONY THOMAS)Also, right click the program icon and select Run as Administrator
8. Re: Error occurs when burning to BD-R DL disc in Encore
poofyboy Jun 22, 2011 9:24 PM (in response to John T Smith)Run As Administrator ... check ... I found that one a long time ago.
<smacks forehead> ... set up the project to create a Blu-Ray ISO and use another program to burn the disk. That works.
9. Re: Error occurs when burning to BD-R DL disc in Encore
studiopeters Oct 3, 2012 11:30 AM (in response to poofyboy)Creating an ISO image and using third party software was the only thing that worked for me. I think this is a bug in Adobe Encore since other software can burn the image perfectly well.
10. Re: Error occurs when burning to BD-R DL disc in Encore
John T Smith Oct 3, 2012 12:28 PM (in response to studiopeters)>think this is a bug
1st, bug report at https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
2nd, parts of Encore are from Roxio, so the problem MAY be with the licensed Roxio modules
11. Re: Error occurs when burning to BD-R DL disc in Encore
Giorgio1957 Oct 5, 2012 3:48 AM (in response to John T Smith)John T Smith wrote:
>think this is a bug
Hi John,
could this mean that other bugs, like unwanted short stops during loop point menu play, will hardly be fixed?
http://www.precomposed.com/blog/2011/01/encore-blu-ray-loop-point-fix/
12. Re: Error occurs when burning to BD-R DL disc in Encore
Stan Jones Oct 5, 2012 5:57 AM (in response to Giorgio1957)Thanks for posting that link to Jon Geddes' blog. I had not seen that latest bit.
We just don't know. While it seems the fix should be easy to code, we don't know what Adobe's plans are for Encore in terms of how much of the code they want to rewrite. This does appear to be a build stage issue, which puts it in the Sonic portion.
But Encore still seems one of the weaker apps in Adobe's line, and since it is bundled with Premiere, I still suspect it does not get the development dollars it needs. But look at the credits sometime. There are a lot of engineers out there working on it.
