5 Replies Latest reply: Sep 3, 2010 1:39 AM by Danielpremiere RSS
    Advice for creating DVD masters for replication
    Danielpremiere Community Member
      I am currently using CS3 (Encore) for creating my DVDs, including the masters which must be used for replication. I don't have a DLT drive, so have always used just standard DVD-video discs, which usually work OK.
      However have recently had lots of problems with Dual-layer discs, and need to find a solution.
      I know the new version (CS5) can burn a DDP image to Hard disc which would be ideal - I was thinking I could perhaps send this on a memory stick to the factory, as FTP is really slow here for 8 or even 4 GB masters. However since CS5 I think doesn't work with Matrox Axio LE hardware yes (and it's also expensive) I don't think I can go down that route yet.
      I have been running the trial of Gear Pro Mastering software, which looks very comprehensive, if almost too many settings (!)
      If I am able to buy this (financially), the question then is, how do I best transfer the master to it from Encore? (from where it can then go on to be made DDP)
      1. Burn the DVD in Encore, and then read the DVD back into Gear (seems a bit clunky and prone to errors?)
      OR
      2. Burn an Image (iso) from Encore, import that into Gear (you have to select that it is DVD-video and I think the layer break point)
      OR
      3. Burn DVD folder from Encore then import that into Gear, and select the layer break point
      One other thing, if I am sure that the layer break has been correctly created on a DVD burn from Encore (and I have no reason do doubt it, after recent tests), is there anything wrong with finding it (the layer break) - using the function in Gear to find it - and then putting that figure into Gear if I was to use option (2) or (3) above??
      One final thing - if sending by DDPimages by FTP is not an option, is it more reliable/acceptable to burn the DDPi to a DVD or put on a memory stick for the factory?
      Any advice greatly received.
      Many thanks
      Daniel
        • 1. Re: Advice for creating DVD masters for replication
          Please can anyone give me any help with this? Hunt, Stan, John T Smith, Neil Wilkes, etc.... I would be most grateful!
          Daniel
          • 2. Re: Advice for creating DVD masters for replication
            John T Smith CommunityMVP
            Sorry... I don't do replication so can't help
            • 3. Re: Advice for creating DVD masters for replication
              Bill Hunt CommunityMVP
              Daniel,
              I am in the same situation as John T. The largest run of discs that I have ever had to do was 10 ea. for a set of 8.
              I know that both Neil Wilkes and Jeff Bellune do replication runs, and will likely be able to offer some info. There are others, too, who use replicators.
              Sorry that I cannot help, but good luck,
              • 4. Re: Advice for creating DVD masters for replication
                Neil Wilkes CommunityMVP
                Danielpremiere wrote:
                OR
                OR
                Many thanks
                Daniel
                Hi Daniel.
                Sorry to have taken so long getting back to you.
                Your best bet is to create a folder from Encore and use that to make the DDP files in GPME.
                One word of caution - do *not* under any circumstances use CSS copy protection out of Encore.
                You'll be sorry of you do, as the SSCRST/DDP combo used is an odd one.
                If CSS is required, create a clean project in Encore, export to a DVD folder, and add CSS in GPME.
                GPME should detect a correctly set Layer Break, However, it is not always so as the Encore Layer Break dialogue is somewhat flaky.
                The best alternative is to take a side trip through PGCEdit (donationware) and set it there - Gear will detect this.
                If you need more help with this, please post straight back - and message me if i am missing in action!!
                • 5. Re: Advice for creating DVD masters for replication
                  Hi Neil,
                  Thanks for the reply. So grateful that you and other can share your expertise!
                  I thought that the folder option from Encore - then GPME for DDP - was probably the best so on Tuesday I did make a master using exactly the route you suggested. I've never bothered with copy protection - because I thought it might  be a problem, though perhaps I should consider it in the future??
                  Luckily on this project, the layer break position was identical between the DVD written in Encore and read in GPME and the image from Encore put into Imgburn, so I had no doubt that it would be OK. (though somehow it was 50/50) bit of luck I guess.
                  I will have a look at the other project where the two programs didn't seem to suggest the same break position - perhaps I just misread it? and have a look at the PGCEdit as you have suggested.
                  Thanks again and I'll let you know how it goes.
                  Daniel
