1 Reply Latest reply on Aug 26, 2010 3:19 AM by Muppet Mark-QAl63s
    Adjusting Curves
    oscar060384
      After selecting a layer, I want to procedurally adjust the curve to an exact number for the Output.  How do I do that thru script?
      Thanks!
        • 1. Re: Adjusting Curves
          Muppet Mark-QAl63s Level 4
          There are several ways in which you can go about this with script.
          Direct:
          1. Using the DOM an art layer has the method adjustCurves(); to which you can pass an array of your values.
          2. You could use the output from the 'scriptlistener' plug-in to make the adjustments.
          3. You could use the output from the 'scriptlistener' plug-in to a load a saved curve file.
          Indirect (putting you adjustment above):
          4. You could copy a curves 'adjustment layer' from another file and place it above your layer.
          5. You could record making a new curve 'adjustment layer' using the output from the 'scriptlistener' plug-in.
          6. You could use the output from the 'scriptlistener' plug-in to make a new curve 'adjustment layer' using a saved curve file.
          If this is all you require then you have no real need for a script you could do most if not all of the above with an action?
