9 Replies Latest reply on Aug 27, 2010 5:35 AM by kglad
    Joining two points
    dalcde Level 1
      I want to ask how do you join two points with a line using actionscript? The points would be constantly moving.
        • 1. Re: Joining two points
          you can use joinF() to draw a line from x1,y1 to x2,y2:
          var canvas:MovieClip=this.createEmptyMovieClip("canvas",this.getNextHighestDepth());
          function joinF(x1:Number,y1:Number,x2:Number,y2:Number):Void{
          with(canvas){
          clear();
          lineStyle(0,0xff0000);
          moveTo(x1,y1);
          lineTo(x2,y2);
          • 2. Re: Joining two points
            dalcde Level 1
            Could you briefly explain the code?
            • 3. Re: Joining two points
              // the as2 drawing api needs a movieclip to apply the draw methods.  so create one:
              var canvas:MovieClip=this.createEmptyMovieClip("canvas",this.getNextHighe stDepth());
              with(canvas){
              // this clears anything previously added to canvas using the drawing api
              // ie, if joinF() is going to be called repeatedly, you need to use the clear() method
              // or all the lines will appear.  try commenting it out and calling joinF() repeatedly
              clear();
              // this establishes a "style" for the line:  0 thickness, red color
              // check the movieclip help files for the other parameters
              // start drawing at x1,y1
              moveTo(x1,y1);
              // draw a line to x2,y2
              lineTo(x2,y2);
              • 4. Re: Joining two points
                dalcde Level 1
                Actually what I don't understand is the "with(canvas)" part. What does it mean? Does it mean all the "this" within the "with" part refers to the canvas? Last question: I am actually making a 3-D graphic and I wan to make a button that would rotate  a cube.The problem is that I want the cube to rotate as long as the mouse is down, i.e. I don't have to keep pressing the button to rotate it several times. I only have to hold the mouse down.
                • 5. Re: Joining two points
                  there is no "this" in that with(){} statement.  the with-statement is shorthand.  the following two snippets are the same:
                  with(canvas){
                  clear();
                  moveTo(x1,y1);
                  lineTo(x2,y2);
                  // and
                  canvas.clear();
                  canvas.lineStyle(0,0xff0000);
                  canvas.moveTo(x1,y1);
                  canvase.lineTo(x2,y2);
                  • 6. Re: Joining two points
                    dalcde Level 1
                    Thanks a lot, but could you help me with the last question at my previous post (I just edited it so you might have not seen it). This is my first attempt to 3-D graphics and I am surprised that most of the problems are not because of the 3-D design!
                    • 7. Re: Joining two points
                      i don't see a question, but you should start a loop (like onEnterFrame or setInterval) when your button is pressed (and clear the loop when the button is released).  in that loop, you should call the joinF().
                      • 8. Re: Joining two points
                        dalcde Level 1
                        Thanks. I haven't thought of that.
                        • 9. Re: Joining two points
                          you're welcome.
