6 Replies Latest reply on Jul 30, 2007 8:25 AM by Newsgroup_User
    AC_RunRunActiveContent.js bug.
    Nathan Whelchel
      ******BUG******
      When specifying content to run, and parameters are provided, the parameters are not dealt with properly.
      Both AC_FL_RunContent() and AC_SW_RunContent() both call AC_GetArgs() where if the parameter is "src" or "movie" calls AC_AddExtension(), which is the failing function.
      Take a look, here is the original function:
      function AC_AddExtension(src, ext)
      if (src.indexOf('?') != -1)
      return src.replace(/\?/, ext+'?');
      else
      return src + ext;
      Do you see the problem? It's obvious isn't it?
      The function call to String.replace specifies a match on the literal "?" and simply adds the extension (.swf or .dcr depending) and appends a single "?" after it. Sound lame? Well it is. Here is the proper function which matches on a "?" and everything after it, adds the extension and appends the rest of the string (i.e the "?" and everything after it), not just a single "?", as it should be:
      return src = src.replace(/\?.*/, ext+'$&' );
      else
      return src + ext;
      Replace this function with the standard one that comes with CS3 to get the proper parameter handling.
      Nathan
        • 1. Re: AC_RunRunActiveContent.js bug.
          Level 7
          Nathan Whelchel wrote:
          > ******BUG******
          At a quick glance, your analysis seems correct. Have you submitted this
          through the bug report form?
          http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
          David Powers, Adobe Community Expert
          Author, "The Essential Guide to Dreamweaver CS3" (friends of ED)
          Author, "PHP Solutions" (friends of ED)
          http://foundationphp.com/
          • 2. Re: AC_RunRunActiveContent.js bug.
            Level 7
            How can I demostrate this bug? It's always worked well for me.
            Don't you mean -
            Replace the standard one that comes with CS3 with this function to get the
            Murray --- ICQ 71997575
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.dreamweavermx-templates.com - Template Triage!
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
            "Nathan Whelchel" <webforumsuser@macromedia.com> wrote in message
            news:f8jp1j$n5s$1@forums.macromedia.com...
            > ******BUG******
            > parameters
            > where if
            > failing
            > function.
            > else
            > return src + ext;
            > and
            > matches
            > of
            > as it
            > should be:
            > else
            > return src + ext;
            > Nathan
            • 3. Re: AC_RunRunActiveContent.js bug.
              Level 7
              I haven't tested it, Murray, but I think this applies only if you add
              FlashVars to the URL.
              • 4. Re: AC_RunRunActiveContent.js bug.
                Level 7
                Ahh - right....
                I've not used that capability.
                "David Powers" <david@example.com> wrote in message
                news:f8kjvm$ooe$1@forums.macromedia.com...
                • 5. Re: AC_RunRunActiveContent.js bug.
                  Nathan Whelchel Level 1
                  Yes, I submitted a bug report - I thought I share this here though and provide an interim solution to an official fix.
                  Yes, I meant replace the CS3 version with the one in the post.
                  Yes, there is only a problem if you pass parameters.
                  Regards,
                  Nathan
                  • 6. Re: AC_RunRunActiveContent.js bug.
                    Level 7
                    Thanks for the clarification.
                    news:f8kvk6$94n$1@forums.macromedia.com...
                    > provide
                    > Regards,
                    > Nathan
