4 Replies Latest reply on Aug 30, 2010 6:52 AM by Captiv8r
    Non-printing Snippets
    l8124525
      Help,
      I am using RoboHelp HTML version 7.02.001
      My problem is that my Snippets are visible in the work area and in the chm when compiled, however, when I generate a Word (or PDF) file from the topic they are nowhere to be seen!
      This is quite a problem as I have used Snippets extensively to synchronise the contents of a German and English help proj
        • 1. Re: Non-printing Snippets
          MergeThis Level 4
          If you assigned an "online only" conditional tag to your snippet placeholders, and your Printed Documentation layout has a "NOT Online" Conditional Build Expression, that might be the cause.
          I just tested this on a single topic whose only content is a snippet (other than an H1 heading) from an existing project (with no conditionalizing), and everything appears in the DOC file. Granted, I'm using RH 8, but I can't see how RH 7 should be any different.
          Leon
          • 2. Re: Non-printing Snippets
            l8124525 Level 1
            Hi Leon,
            I do actually use conditional tags and snippets quite a lot in our
            documentation so I am familiar with the "Print" and "Online" tags. I don't
            know about RH8, but RH7 does not allow you to set a a conditional tag to a
            Snippet at all.
            I just created a blank topic and inserted the snippet which is not being
            printed, same result. I then created a new snippet and inserted it into the
            same topic, it printed! Curiously, if you double-click on the new snippet
            placeholder, it opens for editing however, doing the same to the rogue
            snippet placeholder, it does absolutely nothing however, it will open if you
            select Edit Snippet. The answer may be a corrupt snippet but it shows no
            other evidence of problems other than it will not print.
            Regards
            Steve
            • 3. Re: Non-printing Snippets
              MergeThis Level 4
              Ahhh, snippet corruption. That's what's wrong with the world, today!
              Leon
              • 4. Re: Non-printing Snippets
                LOVED it!
                Thanks for the smile, Leon!
                Rick
