3 Replies Latest reply on Aug 27, 2010 12:33 AM by dgamma
    Check date variable
    dgamma
      Hello I want to be able to select a date from date field, and for whatever date they pick i want it to select the last day for the month they picked.
      ive got this so far:
      var configureEndDate:Date = new Date;
      var testCurrentDay:Date = new Date
      testCurrentDay = dfFrom.selectedDate;
      configureEndDate.setMonth(testCurrentDay. (what do i put here) );
      im not sure what the property for the last day of the month is, if there is any, to put on the end of testCurrentDay. Is there a work around? maybe i could do something like this:
      configureEndDate.setMonth(testCurrentDay. checkMonth() );
      functio ncheckMonth():void
                      if (configureEndDate.month == 1)
                          dfFrom.selectedDate.(what what i put here to change the month to january for the date field, i.e **/01/****)
      Thanks daniel
        • 1. Re: Check date variable
          Gregory Lafrance Level 6
          This will answer your question:
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
            <mx:Script>
              <![CDATA[
                import mx.events.CalendarLayoutChangeEvent;
                private function setLastDay(evt:CalendarLayoutChangeEvent):void{
                  var currDate:Date = (DateField)(evt.target).selectedDate;
                  var newDate:Date = new Date();
                  var currMonth:Number = currDate.getMonth();
                  if(currMonth < 11){
                    newDate.setMonth(currDate.getMonth()+1,1);
                  }else{
                    newDate.setMonth(0, 1);
                  newDate.setDate(newDate.getDate()-1);
                  df.selectedDate = newDate;
            </mx:Script>
            <mx:DateField id="df" change="setLastDay(event);"/>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex Training and Support Services
          • 2. Re: Check date variable
            dgamma Level 1
            nice
            • 3. Re: Check date variable
              dgamma Level 1
              Works great!
