2 Replies Latest reply on Aug 26, 2010 9:48 AM by Handycam
    Video with Avid DV codec is blank in CS5.  Help!
    Handycam Level 1
      I imported some clips into Premiere Pro Cs5 Mac. The audio plays, but the video is just black.  The same clips import into After Effects CS5 without a problem.  I had installed the Avid Codecs into /Library/Quicktime.
      How can I fix this?  I'd prefer to use Premiere.
      If I do a "properties" on one of the clips, here's what it says:
      File Path: /Users/stevelombardi/Documents/WORK/iPad/Video/cvt131 Meringue Frosting DV.mov
      Type: QuickTime Movie
      File Size: 1.0 GB
      Image Size: 853 x 480
      Pixel Depth: 32
      Frame Rate: 29.97
      Source Audio Format: 48000 Hz - 16 bit - Stereo
      Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
      Total Duration: 00:04:45:11
      Average Data Rate: 3.6 MB / second
      Pixel Aspect Ratio: 1.0
      QuickTime Details:
      Movie contains 1 video track(s), 1 audio track(s) and 1 timecode track(s).
      Video:
      There are 8561 frames with a duration of 1/30th.
      Video track 1:
      Duration is 0:00:05:21
      Average frame rate is 1497.02 fps
      Video track 1 contains 1 type(s) of video data:
      Video data block #1:
      Frame Size = 720 x 480
      Compressor = Avid DV25 4:1:1 NTSC 601
      Quality = Most (5.00)
      Audio:
      Audio track 1 contains 1 type(s) of audio data:
      Audio data block #1:
      Format = 16 bit - Stereo
      Rate = 48000 Hz
      Compressor =  16-bit Big Endian
      Timecode:
      Timecode track 1 contains 1 type(s) of data:
      Timecode data block #1:
      Start Time = 01:00:00:00
      Reel name =
