3 Replies Latest reply on Aug 26, 2010 12:52 PM by kglad
    onLoad working at _root level but not at mc_target level, why?
    atrzebunia
      I have two layers in my FLA both with empty movie clips as follows:
      In mc_Empty1, I attach a faded background movieclip as I wait for mc_Empty2 to load a SWF.  Once the SWF is loaded into mc_Empty2, I want to remove the faded background movieclip from mc_Empty1.  When I load the SWF from the main timeline, the onLoad() function works and removes the faded background from mc_Empty1.  However, when I load the SWF from mc_target, the SWF loads, but the onLoad() function does not.  Here's my AS2 code:
      //Loading SWF from main timeline
      mc_Empty1.attachMovie("mcFadedBg", "mc_FadedBg", 1);
      mc_Empty2.loadMovie("My.swf");
      mc_Empty2.onLoad = function():Void
          trace("loaded"); //This works
          removeMovieClip(mc_Empty1.mc_FadedBg); //This works
      //Loading SWF from mc_target
      _parent.mc_Empty1.attachMovie("mcFadedBg", "mc_FadedBg", 1); //This works
      _parent.mc_Empty2.loadMovie("My.swf"); //This works
      _parent.mc_Empty2.onLoad = function():Void //This does not work
           trace("loaded"); //This does not work
           removeMovieClip(_parent.mc_Empty1.mc_FadedBg); //This does not work
      I know I'm targeting properly because the SWF loads as it should, but the onLoad() function does not.  Any thoughts?  I'm using Flash CS4 and publishing for Flash Player 9.
        • 1. Re: onLoad working at _root level but not at mc_target level, why?
          none of your code is probably working the way you think it should work.
          1.  the onLoad() method is called when a movieclip is instantiated (ie, created) as long as the code executes BEFORE the movieclip is instantiated.  it has nothing to do with loading an external file (like My.swf).
          2.  mc_Empty2.onLoad will be call if mc_Empty2 appears on-stage no latter than the frame where your code executes.
          3.  code in a nested movieclip executes AFTER code attached to the parent frame.
          • 2. Re: onLoad working at _root level but not at mc_target level, why?
            atrzebunia Level 1
            Both, mc_Empty1 and mc_Empty2 are instances of mc_Empty already on the stage.  I'm not placing them on the stage using AS.  I just have them in layers; mc_Empty2 is above mc_Empty1 so that the faded background covers the SWF while it's loading.
            I see that I may be using onLoad() incorrectly, or may be thinking the onLoad() = once the SWF is fully loaded.  What function can I use to remove the faded background once the SWF is loaded into mc_Empty2?  I found loadClip() and onLoadComplete() but neither of these work.  Do you have any suggestions?
            Thanks.
            • 3. Re: onLoad working at _root level but not at mc_target level, why?
              so?
              it's easiest to use the moviecliploader class.  it has an onLoadInit() method for its listener that works the way you're thinking those onLoad() methods should work.
