3 Replies Latest reply on Aug 27, 2010 9:19 AM by RazAkhtar
    Effects have annoying lines once saved
      Hi everyone
      I am new to this forum and new to Adobe Premier Elements
      I have version 4.0
      Whenever I try and use Lightning or Particle effects I have a serious problem when I save the video
      The effects have horizontal lines running through them (please note these lines are MORE apparent in the actual vid I made, in this screen capture they don't look that bad)
      can anyone tell me what settings I can use to avoid this?
      I am saving in 1080i (windows media)
      Also in the preview window of my project there are NO lines.
      I am looking to buy AE soon and if I this problem is hardware related (can't see how as Vegas works fine running at full capacity) I need to know
      any help would be greatley appreaciated
        • 1. Re: Effects have annoying lines once saved
          the_wine_snob Level 9
          Welcome to the forum.
          Can you tell us all about your Project Preset, and about the source files that you are using and applying the Effects to? Possibly something there.
          Also, can you give us the complete setting for your WMV Export/Share?
          • 2. Re: Effects have annoying lines once saved
            RazAkhtar Level 1
            Thanks for the speedy response
            My project presets are
            General -
            Frame Size : 1440x1080
            Pixel Aspect Ratio: HD anamorphic (1080) [unchangeable]
            Display Format: 25fps Timecode
            Rendering -
            Compressor: Microsoft Video 1 (Temporal Quality Ratio 0.75) [Could this be the issue?]
            Colour Depth: Thousands of Colours
            The file going in is -
            The finished saved file is
            HD 1080i 30
            29.97 fps
            Video Codec: Windows Media V9
            Encoding Passes : one
            Bitrate Mode: Constant
            Pixel Aspect ratio 4:3
            Keyframe Interval : 4
            Buffer Size: default
            Average video Bitrate: 8000
            Peak video Bitrate: 10000
            Peak video buffer size : 5
            I didn't adjust or change any of these settings
            Hope this helps
            • 3. Re: Effects have annoying lines once saved
              RazAkhtar Level 1
              I have just noticed that this issue is occuring when I view the video Full screen
              When I double click the file it appears ok in windows media but is quite small so when I select Full screen the lines appear.
              this very weird
              When I magnify the preview screen in elements to 100% The lines appear!!
              However when I chosee any other magnifictaion 200, 800, the lines Dissapear!
              It seems like this problem is occuring when the video is being viewed at a specific setting
              could it be my monitor?
