14 Replies Latest reply on Sep 6, 2010 2:26 AM by flexillu10
    How to bind a PHP service to an ArrayCollection
    flexillu10 Level 1
      Ok. i have used Flash builder data connect wizard to connect to my database and generate some PHP services.
      One of them being a get all service.
      I can drag and drop that onto a datagrid fine and it works.
      But
      Could someone please tell me, with as much detail as possible how to call that service, and bind it to an array/arraycollection.
        • 2. Re: How to bind a PHP service to an ArrayCollection
          daslicht Level 2
          you need a Result handler which casts the ResultEvent as ArrayCollection.
          Have a nice day!
          Marc
          • 3. Re: How to bind a PHP service to an ArrayCollection
            flexillu10 Level 1
            daslicht wrote:
            Have a nice day!
            Marc
            could you give me some example code, i use flash builder to generate my result handlers, how do i create one for this service?
            • 4. Re: How to bind a PHP service to an ArrayCollection
              daslicht Level 2
              do you like to post your service call, please?
              Cheers
              Marc
              • 5. Re: How to bind a PHP service to an ArrayCollection
                flexillu10 Level 1
                Hello,
                Sorry all i have is the service shown in my above post, it was generated by flash builder.
                I just want to call it, and store it in an array, how do i do that?
                • 6. Re: How to bind a PHP service to an ArrayCollection
                  flexillu10 Level 1
                  if i right click on it and select generate service call; this code is generated
                  protected function getAllTbl_images():void
                              getAllTbl_imagesResult.token = tblimagesService.getAllTbl_images();
                  • 7. Re: How to bind a PHP service to an ArrayCollection
                    Subeesh Arakkan Level 4
                    Check this code. You need to import the correct namespace of the service.
                         xmlns:mx="library://ns.adobe.com/flex/mx"
                         minWidth="955" minHeight="600">
                         <fx:Script>
                              <![CDATA[
                                   import mx.collections.ArrayCollection;
                                   import mx.rpc.events.FaultEvent;
                                   import mx.rpc.events.ResultEvent;
                                   [Bindable]private var images:ArrayCollection;
                                   protected function myService_resultHandler(event:ResultEvent):void
                                        images = event.result as ArrayCollection;
                                   protected function myService_faultHandler(event:FaultEvent):void
                                        trace(event.fault.faultString);
                                   protected function button1_clickHandler(event:MouseEvent):void
                                        myService.tblimagesService.getAllTbl_images();
                         </fx:Script>
                         <s:Button label="Get Data" click="button1_clickHandler(event)"/>
                         <fx:Declarations>
                              <services:TblImagesService id="myService"
                                   result="myService_resultHandler(event)" fault="myService_faultHandler(event)"/>
                         </fx:Declarations>
                    </s:Application>
                    • 8. Re: How to bind a PHP service to an ArrayCollection
                      daslicht Level 2
                      Yeah that should do the job!
                      • 9. Re: How to bind a PHP service to an ArrayCollection
                        flexillu10 Level 1
                        thanks, but how do i know which namespace it is?
                        It says the prefix services is unbound?
                        • 10. Re: How to bind a PHP service to an ArrayCollection
                          start typing the custom TblImagesService tag and flash builder will automataiically import the namespace for you just like the code completion for all the other flex controls in mxml
                          • 11. Re: How to bind a PHP service to an ArrayCollection
                            flexillu10 Level 1
                            ok, not sure if it's working. In the click handler i get an error:
                            Multiple markers at this line:
                            -myService
                            -1119: Access of possibly undefined property tblimagesService through a reference with static type
                            services.tblimagesservice:TblimagesService.
                            and when i try and type it the auto complete can't find it:
                            any ideas?
                            • 12. Re: How to bind a PHP service to an ArrayCollection
                              I meant to use the code completion when you create the service instance in MXML.
                                   xmlns:services="services.*"
                                   <fx:Script>
                                        <![CDATA[
                                   </fx:Script>
                                   <fx:Declarations>
                                   </fx:Declarations>
                              </s:Application>
                              The previous example is modified to include the namespace in the application tag, assuming that yourTblImagesService is in the services folder. If it is different, change the namespace declaration .
                              • 13. Re: How to bind a PHP service to an ArrayCollection
                                flexillu10 Level 1
                                ok yeah i think its working anyway, do you know any easy way to test it?
                                • 14. Re: How to bind a PHP service to an ArrayCollection
                                  flexillu10 Level 1
                                  When i debug the application i can look through the array and see the data i want, but when i call toString() on one of the items in the arraycollection i am getting "Object:Imagedetails[]"
                                  Can anyone tell me how i can get the data out of the object?
                                  Do i need a call responder?
