8 Replies Latest reply on Sep 1, 2010 4:46 PM by iceministries
    Can Military Time be reset to Regular time in Flash File?
    iceministries
      I am working on a site that has a clock but it displays in military time, is there a way to change it to regular time.
      The following is the Action script:
      months_array = ["JANUARY", "FEBRUARY", "MARCH", "APRIL", "MAY", "JUNE", "JULY", "AUGUST", "SEPTEMPBER", "OKTOBER", "NOVEMBER", "DECEMBER"];
      days_array = ["MON", "TUE", "WED", "THUR", "FRI", "SAT", "SUN"];
      date = new Date();
      var dayOfWeek_array = new Array("SUN", "MON", "TUE", "WED", "THUR", "FRI", "SAT");
      var today_date = new Date();
      var day_str = dayOfWeek_array[today_date.getDay()];
      F_clock = function ()
      var _loc1 = new Date();
      var _loc4;
      var _loc3;
      var _loc2;
      if (_loc1.getSeconds() < 10)
      _loc4 = "0" + _loc1.getSeconds();
      else
      _loc4 = _loc1.getSeconds();
      } // end else if
      if (_loc1.getMinutes() < 10)
      _loc3 = "0" + _loc1.getMinutes();
      else
      _loc3 = _loc1.getMinutes();
      } // end else if
      if (_loc1.getHours() < 10)
      _loc2 = "0" + _loc1.getHours();
      else
      _loc2 = _loc1.getHours();
      } // end else if
      if (_loc1.getHours() < 12)
      else
      _loc2 = _loc1.getHours() - 12;
      } // end else if
      if (hours >= 12)
      hours = hours - 12;
      ampm = "PM";
      else
      ampm = "AM";
      } // end else if
      if (hours == 0)
      hours = 12;
      } // end if
      time_txt.text = _loc2 + "." + _loc3 + " " + ampm + ", " + date.getDate() + " " + dayOfWeek_array[_loc1.getDay()] + " " + months_array[date.getMonth()] + " " + date.getFullYear();
      F_clock();
      setInterval(F_clock, 1000);
        • 1. Re: Can Military Time be reset to Regular time in Flash File?
          From what I can see, the code you show is displaying non-military time.  Is there a specific problem with it?
          • 2. Re: Can Military Time be reset to Regular time in Flash File?
            iceministries Level 1
            The message you sent requires that you verify that you
            are a real live human being and not a spam source.
            To complete this verification, simply reply to this message and leave the subject line intact.
            We apologize for any inconvenience this may cause but we have been receiving a volume of UNWANTED SPAM therefore we had to initiate this procedure to stop them from coming.  Once you reply to this email you will no longer be required to do this anymore and you email will go through as normal.
            God bless you for your understanding and patience
            ICEMINISTRIES, INT&#39;L STAFF
            The headers of the message sent from your address are show below:
            From forums@adobe.com Fri Aug 27 13:46:46 2010
            Received: from mail.sgaur.hosted.jivesoftware.com (:47368)
                 by gator226.hostgator.com with esmtp (Exim 4.69)
                 (envelope-from <forums@adobe.com>)
                 id 1Op3ws-00029H-AY
                 for icem@iceministries.org; Fri, 27 Aug 2010 13:46:46 -0500
            Received: from sgaurwa44p (unknown )
                 by mail.sgaur.hosted.jivesoftware.com (Postfix) with ESMTP id EAF64E31E84
                 for <icem@iceministries.org>; Fri, 27 Aug 2010 12:46:48 -0600 (MDT)
            Date: Fri, 27 Aug 2010 12:46:45 -0600
            Reply-To: clearspace-1069710804-40322-2-3089266@mail.forums.adobe.com
            To: Michael Anson <icem@iceministries.org>
            Message-ID: <1084768362.2172121282934808955.JavaMail.jive@sgaurwa44p>
            Subject: Can Military Time be reset to Regular time
            in Flash File?
            MIME-Version: 1.0
            Content-Type: multipart/mixed;
                 boundary="----=_Part_220461_426678043.1282934805785"
            Content-Disposition: inline
            • 3. Re: Can Military Time be reset to Regular time in Flash File?
              Sorry for the delay in responding, Hurricane Earl just went through our island so we had power outages.  Anyway, in answer to your question...the clock will not change from "PM" to "AM" and at 12 a.m. it goes to 0:00, instead of 12:00.  Is there any way that this can be fixed?
              • 4. Re: Can Military Time be reset to Regular time in Flash File?
                You appear to have an issue with the hours logic... what you have would make 12 noon appear as a 0.
                if (_loc1.getHours() < 12)                 // should be <= 12
                else
                I also notice you are using an hours variable, but nowhere do you declare it nor assign it a value before you test it, which cannot be helping...
                if (hours >= 12)       // hours is undefined at this point
                hours = hours - 12;
                ampm = "PM";
                else
                ampm = "AM";
                You may be confusing yourself with the various variables you have at work, so it might help you to get those under control.  You should be able to decide AM vs PM based solely on the getHours() value.   getHours() values > 12 should be the only case where you subtract 12 to get the non-military PM hour values.  A getHours() value of zero is all you need to determine when to change it to be 12 (AM)
                • 5. Re: Can Military Time be reset to Regular time in Flash File?
                  From forums@adobe.com Wed Sep 01 11:27:53 2010
                  Received: from mail.sgaur.hosted.jivesoftware.com (:35616)
                       id 1OqqAD-0006bX-4a
                       for icem@iceministries.org; Wed, 01 Sep 2010 11:27:53 -0500
                  Received: from sgaurwa43p (unknown )
                       by mail.sgaur.hosted.jivesoftware.com (Postfix) with ESMTP id 039BC2409A27
                       for <icem@iceministries.org>; Wed,  1 Sep 2010 10:27:49 -0600 (MDT)
                  Date: Wed, 01 Sep 2010 10:27:38 -0600
                  Reply-To: clearspace-137041958-40322-2-3101006@mail.forums.adobe.com
                  Message-ID: <1498639528.786471283358469050.JavaMail.jive@sgaurwa43p>
                  in Flash File?
                  MIME-Version: 1.0
                       boundary="----=_Part_80105_2022858504.1283358458604"
                  • 7. Re: Can Military Time be reset to Regular time in Flash File?
                    Can you mark this posting as answered?  Below is the revised code, with all redundant or unused elements removed, misspellings corrected, and punctuation done properly...
                    var months_array = ["JANUARY", "FEBRUARY", "MARCH", "APRIL", "MAY", "JUNE", "JULY", "AUGUST", "SEPTEMBER", "OCTOBER", "NOVEMBER", "DECEMBER"];
                    function F_clock()
                    var date = new Date();
                    var mins = date.getMinutes();
                    var hrs = date.getHours();
                    if (mins < 10)
                      mins = "0" + mins;
                    if (hrs >= 12)
                      ampm = "PM";
                      if(hrs > 12)
                       hrs = hrs - 12;
                    else
                      ampm = "AM";
                    if(hrs == 0)
                      hrs = 12;
                    if (hrs < 10)
                      hrs = "0" + hrs;
                    time_txt.text = hrs + ":" + mins + " " + ampm + ", " + date.getDate() + " " + dayOfWeek_array[date.getDay()] + " " + months_array[date.getMonth()] + " " + date.getFullYear();
                    F_clock();
                    • 8. Re: Can Military Time be reset to Regular time in Flash File?
                      From forums@adobe.com Wed Sep 01 18:46:08 2010
                      Received: from mail.sgaur.hosted.jivesoftware.com (:56367)
                           id 1Oqx0K-0006Tu-ST
                           for icem@iceministries.org; Wed, 01 Sep 2010 18:46:08 -0500
                           by mail.sgaur.hosted.jivesoftware.com (Postfix) with ESMTP id 59AB1E30E91
                           for <icem@iceministries.org>; Wed,  1 Sep 2010 17:46:15 -0600 (MDT)
                      Date: Wed, 01 Sep 2010 17:46:12 -0600
                      Reply-To: clearspace-137041958-40322-2-3102139@mail.forums.adobe.com
                      Message-ID: <1961060211.868781283384775374.JavaMail.jive@sgaurwa43p>
                      in Flash File?
                      MIME-Version: 1.0
                           boundary="----=_Part_88452_225469154.1283384772131"
