1 Reply Latest reply on Sep 13, 2010 4:14 AM by Alex Uhlmann
    Integration - Error: The synchronized type much have a property marked with the [SyncId] metadata.
    adooba-jooba
      Can't able to get integration library integrated with flex3 builder. What am I missing?
      Flex 3
      Main file: main.mxml
      No other setting on flex compiler for metadata
      libraries used:parsley-flex3-2.2.2.swc,spicelib-flex-2.2.2.swc,integration-flex3-0.13.swc
      Compiles well but throws the following error on runtime:
      Cause(0): Initialization of ObjectDefinition for Class com.adobe.cairngorm.integration.data::DataCache failed - cause: Error: The synchronized type much have a property marked with the [SyncId] metadata.
      at com.adobe.cairngorm.integration.data::DataCache/findIdentityProperty()
      at com.adobe.cairngorm.integration.data::DataCache/initialise()
      at Function/http://adobe.com/AS3/2006/builtin::apply()
      [truncated]
      AppContext.mxml
      <mx:Object xmlns:mx="http://www.adobe.com/2006/mxml"
      xmlns:data="com.adobe.cairngorm.integration.data.*" xmlns:domain="com.test.domain.*">
      <data:DataCache type="com.test.domain.TestItem" />
      </mx:Object>
      main.mxml
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:spicefactory="http://www.spicefactory.org/parsley">
      <mx:Script>
      <![CDATA[
      import com.test.domain.TestItem;
      import org.spicefactory.parsley.core.messaging.ErrorPolicy;
      private function init() : void {
      new TestItem();
      </mx:Script>
      <spicefactory:ContextBuilder>
      <spicefactory:FlexConfig type="{ AppContext }"/>
      <spicefactory:Settings unhandledMessageErrors="{ErrorPolicy.RETHROW}"/>
      </spicefactory:ContextBuilder>
      <mx:Label text="Hello there!" />
      </mx:Application>
      TestItem.as
      package com.test.domain
      import mx.utils.ObjectUtil;
          public class TestItem  {
              [SyncId]
              public var id:int;
              public var value:String;
               public function toString():String
                  return ObjectUtil.toString(this);
