2 Replies Latest reply on Aug 28, 2010 6:05 AM by dgamma
    How to check if spark navigator content has been clicked
    dgamma
      I've been trying to run a function to call when the navigator conent has been clicked or changed, but none of these events seem to be working? any ideas?
      daniel
        • 1. Re: How to check if spark navigator content has been clicked
          ShardulSingh Level 3
          All is working fine.Pls check with the example below. You can click on the red navigator content then you will find a Alert. And also when you will
          add a button isnide the navigator content then also you will find another Alert.Let me know if you have any issue with this.
                         xmlns:mx="library://ns.adobe.com/flex/mx"
                         minWidth="955" minHeight="600">
              <fx:Script>
                  <![CDATA[
                      import mx.controls.Alert;
                      import mx.events.FlexEvent;
                      import spark.components.Button;
                      protected function navigatorcontent1_clickHandler(event:MouseEvent):void
                          Alert.show("Working fine.");
                      protected function navigatorcontent1_updateCompleteHandler(event:FlexEvent):void
                          Alert.show("navigatorContent is updated.")
                      protected function addToNavigatorcontent(event:MouseEvent):void
                          var btn : spark.components.Button = new spark.components.Button();
                          btn.label = "Added on navigatorContennt";
                          btn.width = 100;
                          btn.height = 50;
                          navigatorContent.addElement(btn);
              </fx:Script>
              <fx:Declarations>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <mx:VBox>
                  <s:NavigatorContent id="navigatorContent" width="400" height="150" backgroundColor="0xFF0000" click="navigatorcontent1_clickHandler(event)" updateComplete="navigatorcontent1_updateCompleteHandler(event)">
                  </s:NavigatorContent>
                  <mx:Button label="Add something to NavigatorContent" width="250" click="addToNavigatorcontent(event)" />
              </mx:VBox>
          </s:Application>
          with Regards,
          Shardul Singh Bartwal
