0 Replies Latest reply on Aug 28, 2010 2:40 AM by mosamna
    passing html table as string with ampersand values problem.
    mosamna
      Hi there,
      I'm converting a datagrid table into a string having html table code inside then passing this string to an external ABAP html file.
      The problem is as follows: whenever an item having an ampersand like "I am a friend of Micheal&Alex"  the html file will show only this much  "I am a friend of Micheal" without the rest of the string.
      my code:
      private function convertDGToHTMLTable(dg:DataGrid):String {
           var font:String = dg.getStyle('fontFamily');
           var size:String = dg.getStyle('fontSize');
           var str:String = '';
           var colors:String = '';
           var style:String = 'style="font-family:'+font+';font-size:'+size+'pt;"';
           var hcolor:Array;
           //Retrieve the headercolor
           if(dg.getStyle("headerColor") != undefined) {
                hcolor = [dg.getStyle("headerColor")];
           } else {
                hcolor = dg.getStyle("headerColors");
           //Set the htmltabel based upon knowlegde from the datagrid
           str+= '<table width="'+dg.width+'"><thead><tr width="'+dg.width+'" style="background-color:#' +Number((hcolor[0])).toString(16)+'">';
           //Set the tableheader data (retrieves information from the datagrid header
           for(var i:int = 0;i<dg.columns.length;i++) {
                colors = dg.getStyle("themeColor");
                if(dg.columns[i].headerText != undefined) {
                     str+="<th "+style+">"+dg.columns[i].headerText+"</th>";
                } else {
                     str+= "<th "+style+">"+dg.columns[i].dataField+"</th>";
           str += "</tr></thead><tbody>";
           colors = dg.getStyle("alternatingRowColors");
           //Loop through the records in the dataprovider and
           //insert the column information into the table
           for(var j:int =0;j<dg.dataProvider.length;j++) {
                str+="<tr width=\""+Math.ceil(dg.width)+"\">";
                for(var k:int=0; k < dg.columns.length; k++) {
                     //Do we still have a valid item?
                     if(dg.dataProvider.getItemAt(j) != undefined && dg.dataProvider.getItemAt(j) != null) {
                          //Check to see if the user specified a labelfunction which we must
                          //use instead of the dataField
                          if(dg.columns[k].labelFunction != undefined) {
                               str += "<td width=\""+Math.ceil(dg.columns[k].width)+"\"                               "+style+">"+dg.columns[k].labelFunction(dg.dataProvider.getItemAt(j),dg.columns[k].dataFi eld)+"</td>";
                          } else {
                               //Our dataprovider contains the real data
                               //We need the column information (dataField)
                               //to specify which key to use.
                               str += "<td width=\""+Math.ceil(dg.columns[k].width)+"\" "+style+">"+dg.dataProvider.getItemAt(j)[dg.columns[k].dataField]+"</td>";
                str += "</tr>";
           str+="</tbody></table>";
           return str;
      private function loadDGInExcel(dg:DataGrid):void {
           var htmltable:String = convertDGToHTMLTable(dg);
           htmltable = htmltable.replace(/&/g,"&amp;");
           var variables:URLVariables = new URLVariables("param1="+htmltable);
           //Setup a new request and make sure that we are
           //sending the data through a post
           var u:URLRequest = new URLRequest(link);
           u.method = URLRequestMethod.POST;
           navigateToURL(u,"_blank");
           u.data = variables; //Pass the variables
