0 Replies Latest reply on Aug 28, 2010 4:50 AM by kvanderwende
    DataGrid rendering problem
    kvanderwende Level 1
      I have an ApplicationControlBar above a data grid.  The data grid has widths specified and is bound to a data source that is populated by a service call.  The mark up below causes the description column to disappear and the header row is about 10 times taller than it should be.  If I put an empty label inside  the application bar it all loads as expected.  I tried putting an updateComplete handler on the grid but I found two problems.  Adding a trace to the method handler showed that it just kept firing over and over.  It also prevented resize of the grid columns.
      <mx:VBox
      height="100%" width="80%" horizontalScrollPolicy="off" verticalScrollPolicy="off">
      <mx:ApplicationControlBar width="100%" horizontalGap="0" id="docsAppBar">
      <mx:Button click="browseForDocs()"
                        id="
      docsTabUploadButton"
                        label="
      Upload Document"
                        enabled="
      {MediaManagerModel.activateUploadButton}"/>
      </mx:ApplicationControlBar>
      <mx:HBox width="100%" height="100%">
      <mx:DataGrid dataProvider="{tabMediaList}"
                        id="
      docGrid"
                        width="
      100%"
                        height="
      100%"
                        verticalGridLines="
      true"
                        variableRowHeight="
      true"
                        wordWrap="
      true"
                        sortableColumns="
      false"
                        editable="
      false"
                        allowDragSelection="
      true"
                        dragEnabled="
      true"
                        dragMoveEnabled="
      true"
                        dropEnabled="
      true"
                        dragComplete="updateRowPositions()"
                        itemClick="updateCurrentMediaObject()"
      <mx:columns>
      <mx:DataGridColumn width = "20" id="displayOrderCol" headerText="#"  dataField="displayOrder" labelFunction="MediaManagerModel.getMediaDisplayOrder"/>
      <mx:DataGridColumn width = "250" id="mediaNameCol" headerText="File Name" dataField="mediaName" />
      <mx:DataGridColumn width = "120" id="mediaTypeCol" headerText="Type"  dataField="mediaType" labelFunction="MediaManagerModel.getMediaTypeDisplay"/>
      <mx:DataGridColumn width = "60" id="buyerCol" headerText="Public" dataField="buyer" labelFunction="MediaManagerModel.getPublicDisplay" textAlign="center"/>
      <mx:DataGridColumn width = "50" id="mediaSizeCol" headerText="Size" dataField="mediaSize" labelFunction="MediaManagerModel.getMediaSizeDisplay" textAlign="center"/>
      <mx:DataGridColumn width = "90" id="inputDateCol" headerText="Date Added" dataField="inputDate" labelFunction="MediaManagerModel.getMediaInputDateDisplay" textAlign="center"/>
      <mx:DataGridColumn width= "240" id="mediaDescrCol" headerText="Description" dataField="mediaDescr" />
      </mx:columns>
      </mx:DataGrid>
      </mx:HBox>
      </mx:VBox>
      If I add <mx:Label/> inside the ApplicationControlBar everything renders fine.  Any ideas?
