3 Replies Latest reply on Aug 28, 2010 6:20 PM by the_wine_snob
    Output file size doubled
    Olive man
      I have created a movie in Premiere Elements that uses hi-def video, still images, narration and a soundtrack. The movie is about 1 hour long. Once the movie reached its final length of about 1 hour, the output file size of the movie to be burned to Blu-ray was consistently around 11 GB. For reasons I don't understand, the output file size has abruptly grown to 26 GB. I have not added any significant footage or effects since I reached the 1 hour mark. I've only made very small tweaks to the audio balance and transitions.
      The only thing that I can think of that might have caused this growth is that I went into the project settings and turned off "optimize stills." I may also have turned on "maximum bit depth." When I clicked ok, Premiere Elements told me that it had to re-render the project, which i did so. Since then, though, i have re-enabled "optimize stills" and turned off "maximize bit depth." I have also re-rendered the project again. My file size is still 26 GB.
      I am running PE on a 3.06 GHZ laptop with 6 GB of ram. Running Windows 7, 64-bit.
      Has anyone else run into this issue?
        • 1. Re: Output file size doubled
          the_wine_snob Level 9
          File size is dependent on Bit-Rate and on Duration. If you have upped the Bit-Rate, you will see an increase in file size. Will the Project still fit on your BD? If so, and you want highest quality, the Bit-Rate and Bit-Depth can just stay higher. If space is an issue, then you can drop these down a bit.
          Something else to think about and look for is has your Duration changed. This can be caused by "Orphans," out beyond where you intend your Timeline to end. This ARTICLE will give you some tips. This is easy to check.
          • 2. Re: Output file size doubled
            Olive man Level 1
            That was it! I had an orphan audio clip way out on my timeline. Once I cleared it, my project reverted to 9 GB.
            Thanks a lot for your quick and expert help. You saved me a lot of money. Now I can burn copies of my movie on 25 GB Blu-ray discs rather than on 50 GB discs.
            • 3. Re: Output file size doubled
              Those danged "Orphans" have bitten a lot of folk, as you can see - I wrote an article on it.
              The most common cause is where one drags a lot of Assets onto the Timeline and then begins tightening things up. In a moment, the view out to the end of the Timeline is not there anymore, as one works near the beginning. Assets, or pieces of them, get left behind.
              Glad that you found it, and cleared it.
              Happy editing,
