24 Replies Latest reply on Nov 11, 2011 8:48 AM by Colin Brougham
    Problem with Mercury Engine
    aJockster
      I am on the mac platform using an 8 core system with 2 x Quadro FX 4800 cards in my system along with 32 gig Ram.
      I can even have 2 layers of video showing without a red line appearing. I suspect the mercury engine is not enabled somehow. I have installed the latest Nvidia drivers along with CUDA 3.1
      I am not given the option to switch between Software or Mercury Hardware, it's greyed-out.
      Any thoughts would be most appreciated. As you can imagine this is becoming very frustrating.
      Regards,
      Allan
      See screen Grab:
        • 1. Re: Problem with Mercury Engine
          Colin Brougham Level 6
          You may have to disable or remove one of the cards.
          • 2. Re: Problem with Mercury Engine
            aJockster Level 1
            I will give that a try, sadly I run 3 monitors and each card only supports 2 monitors.
            Thanks for your thought.
            Allan
            • 3. Re: Problem with Mercury Engine
              aJockster Level 1
              Is there an easy way to disble, without the need to remove a card?
              Cheers,
              Allan
              • 4. Re: Problem with Mercury Engine
                I can tell you how to do it Windows, but I have no idea for OS X. I suspect you can't; this is probably one of those "ease of use" features of the Mac
                Since you already have the latest drivers installed, that's my best guess about the issue. The only way to know is to physically remove one of the cards, and see if you get GPU acceleration as an option.
                EDIT: Just remembered that I think there is a OS X version issue that can prohibit CUDA GPU acceleration; I think you need the last point update of 10.5 or 10.6 to enable this. Don't quote me on that, but I think there's a thread around here somewhere to that effect.
                • 5. Re: Problem with Mercury Engine
                  aJockster Level 1
                  Colin,
                  much appreciated. I will remove the card tomorrow, its nerly 3am here, time for bed soon.
                  I have just ordered a 12 core system, now Im thinking maybe I should have moved back to PC.
                  Allan
                  • 6. Re: Problem with Mercury Engine
                    aJockster Level 1
                    Colin,
                    I have removed one card and I still cannot activate the Mercury engine.
                    Any other thoughts. I reinstalled the CUDA 3.1 software but still no joy
                    Allan
                    • 7. Re: Problem with Mercury Engine
                      aJockster Level 1
                      I tried one other situation just to eliminate another possible cause:
                      Ive now tried 64Bit as well as 32Bit and still cannot activate the Mercury Engine.
                      Going to bed now, hopefully when I wake up some of you wonderful Guru's will have an answer for me
                      I presume all i needed to do was install the Nividia Driver and CUDA 3.1 am I missing anything?
                      Cheers,
                      Allan
                      • 8. Re: Problem with Mercury Engine
                        rejdmast1 Level 2
                        Make sure you have the latest version of OSX installed.
                        Run these steps to make sure Premiere sees your graphics card and that it is listed in the
                        cuda_supported_cards.txt
                        Step 1. Go to the Premiere CS5 installation folder.
                        Step 2. Find the file “GPUSniffer.exe” and run it in a command prompt (cmd.exe) and make sure it lists your card.
                        Step 3. Find the file: “cuda_supported_cards.txt” and edit it and  add your card (take the name from the line: CUDA device details: Name:  GeForce GTX 295 Compute capability: 1.3
                        So in my case the name to add is: GeForce GTX 295
                        Step 4. Save that file and we’re almost ready.
                        Link to the full hack:
                        http://forums.adobe.com/message/2789255#2789255
                        • 9. Re: Problem with Mercury Engine
                          Run these steps to make sure Premiere sees your graphics card and that it is listed in the cuda_supported_cards.txt
                          None of this is necessary. The Quadro FX 4800 is an officially supported card, both in Windows and Mac.
                          This is worthwhile advice, however. According to the system requirements, "Mac OS X v10.6.3 required for GPU-accelerated performance." Anything earlier will prohibit Premiere from using the GPU.
                          • 10. Re: Problem with Mercury Engine
                            aJockster Level 1
                            Im running 10.6.4
                            Is there any software that I can run that can confirm my Quadro is working correctly. The reason I ask this is because since day 1 I have not been impressed with these cards, considering I installed two of these on the same system. I saw ZERO performance gain when using them in FCP. After reading a lot about Premiere and CUDA I thought for the first time I might see some benefit to having these cards.
                            This is quite frustrating
                            Once again many thanks for your thoughts, it's a shame no one from ADOBE has pitched-in.
                            Gentle reminder to all, im running CS5 on a Mac.
                            Allan
                            • 11. Re: Problem with Mercury Engine
                              shooternz Level 6
                              The fact that you can see the graphics on your screen is probably an indication that it is working in some manner.
                              In a Windows PC ( eg mine) I can go to a NVIDIA set up page and run through all the setup and options for the card and driver.  This includes some tests.
                              FWIW.  I have a Quadro FX 3800 installed.  Combined with the MPE technology and CS5...its benefits are significant.
                              Not sure what way or how FCP makes use of graphic card processing if any.  I doubt that it is as significant as MPE /CUDA.
                              • 12. Re: Problem with Mercury Engine
                                rejdmast1 Level 2
                                Allan,
                                Make sure PP is at least seeing your card.
                                If it is, at least it will eliminate one unknown.
                                I wish I could help you more but I'm a PC guy, not a MAC guy.
                                • 13. Re: Problem with Mercury Engine
                                  aJockster Level 1
                                  My head is about to explode.
                                  I have tried as many variations as I can possibly think to try and get this working. I have tried another card, change slots, you name it Iv'e tried it.
                                  My last resort is to completely wipe my system and install a fresh OS and reinstall CS5 and prey that that works.
                                  I have no way to find out if PP is seeing my Quadro/s. I wish I could atleast establish that, but on a MAC I cannot find out how?
                                  Any other thoughts please let me know.
                                  Allan
                                  • 14. Re: Problem with Mercury Engine
                                    Bob_McConnell Level 1
                                    Try running CINEBENCH and you will get opengl comparisons for similar machines.
                                    Bob
                                    • 15. Re: Problem with Mercury Engine
                                      Powered by Design Level 4
                                      There is a text file you can open to see if you card is listed in the approved card list.
                                      Just open that file and see if your card is listed.
                                      Here is the instructions of the hack.
                                      Just go straight to step 3
                                      Let us know what you see in that file.  COPY and past it here
                                      GLenn
                                      Step 2. Find the file "GPUSniffer.exe" and run it in a command prompt (cmd.exe). You should see something like that:
                                      Device: 00000000001D4208 has video RAM(MB): 896
                                      Vendor string: NVIDIA Corporation
                                      Renderer string: GeForce GTX 295/PCI/SSE2
                                      Version string: 3.0.0
                                      OpenGL version as determined by Extensionator...
                                      OpenGL Version 2.0
                                      Supports shaders!
                                      Supports BGRA -> BGRA Shader
                                      Supports VUYA Shader -> BGRA
                                      Supports UYVY/YUYV ->BGRA Shader
                                      Supports YUV 4:2:0 -> BGRA Shader
                                      Testing for CUDA support...
                                      Found 2 devices supporting CUDA.
                                      CUDA Device # 0 properties -
                                      Total Video Memory: 877MB
                                      CUDA Device # 1 properties -
                                      CUDA Device # 0 not choosen because it did not match the named list of cards
                                      Completed shader test!
                                      Internal return value: 7
                                      If you look at the last line it says the CUDA device is not chosen because it's not in the named list of card. That's fine. Let's add it.
                                      Step 3. Find the file: "cuda_supported_cards.txt" and edit it and add your card (take the name from the line: CUDA device details: Name: GeForce GTX 295 Compute capability: 1.3
                                      Step 4. Save that file and we're almost ready.
                                      Step 5. Go to your Nvidia Drivercontrol panel (im using the latest 197.45) under "Manage 3D Settings", Click "Add" and browse to your Premiere CS5 install directory and select the executable file: "Adobe Premiere Pro.exe"
                                      Step 6. In the field "multi-display/mixed-GPU acceleration" switch from "multiple display performance mode" to "compatibilty performance mode"
                                      Step 7. That's it. Boot Premiere and go to your project setting / general and activate CUDA
                                      • 16. Re: Problem with Mercury Engine
                                        aJockster Level 1
                                        Update:
                                        I decide to wipe my system and re-install Snow Leopard version 10.6. After completing the installation I installed CS5, CUDA 3.1 and launched Premiere, sadly the Mercury engine was still greayed out.
                                        I was then prompted to  update some software in Snow Leapard which I did. Still no Joy!
                                        Then out of the blue a CUDA window appeared and asked me to update to 3.1.4 which I did. Launched Premier Pro and to my surprise the Mercury Engine option becam available.
                                        To one and all who has tried to help me, thank you very much for your time.
                                        Regards,
                                        Allan
                                        • 17. Re: Problem with Mercury Engine (Mac 10.6.4)
                                          aelightsong
                                          On Mac - repaired the drive permissions and then it showed up as an option in project settings.
                                          • 18. Re: Problem with Mercury Engine
                                            Bertrand Delecroix
                                            Just got a stupid joke from the Premiere Pro CS 5.5 system.
                                            The Cuba motor was not fonctionning because of a space at the end of the names GeForce GTX 470 (Space).
                                            I supressed the space and back to normal.
                                            The file was OK before and suddenly it was not possible to ennable the motor ! Update ?
                                            • 19. Re: Problem with Mercury Engine
                                              Jeff Bellune Level 5
                                              That's correct.  Every time you update or upgrade, you'll have to re-do the hack for an unsupported card.
                                              -Jeff
                                              • 20. Re: Problem with Mercury Engine
                                                ...you'll have to re-do the hack for an unsupported card.
                                                ...except that the the GTX 470 is an officially-supported card for the Cuba Motor. Something is fishy about this. It does suggest something weird...
                                                Bertrand, are you running the latest drivers for your GPU?
                                                • 21. Re: Problem with Mercury Engine
                                                  lasvideo Level 4
                                                  Do you have to speak Spanish for the CUDA Engine to become the CUBA Motor  ;-)
                                                  • 22. Re: Problem with Mercury Engine
                                                    Bertrand Delecroix Level 1
                                                    Just to precise it was the GTX 460 and I did the hack and that was not working. I did have to supress manualy a space in the Cuda suppurted card file. Don't know why but that did the trick !
                                                    If it can help someone !
                                                    • 23. Re: Problem with Mercury Engine
                                                      No sorry French !!!!
                                                      • 24. Re: Problem with Mercury Engine
                                                        That makes more sense. There's a reason this is called a "hack"--you're taking matters into your own hands and you're responsible for any unexpected behavior as a result.
