4 Replies Latest reply on Aug 31, 2010 3:00 AM by mikeybabes68
    Unused Rectangle frame removal
    mikeybabes68 Level 1
      Hi scripters
      I am using data merge to generate some menu tables via simple csv import, however i generate about 300pages worth.
      The template uses a mixture of a graphic file or plain text as inported data.
      however when i have completed i need to remove all unused frames from all the pages. the reason is i have some frames and text next to eachother as part of the design when not used i would hand select all them with the visual cross as seen visuall and just delete.
      i am unable to find how i can check all frames which have no files associated to them and just do a bulk delete.
      I expect the answer is less words this the message.
      I new to scripting, and trying to use reference is a task in itself.
      Any pointers is much appreciated.
      It's a shame data merge does only just the basic part, the tidy up process just takes as long.
      thanks for reading.
        • 1. Re: Unused Rectangle frame removal
          brettpolo Level 1
          Assuming that the graphic frames are all rectangles:
          rects = app.activeDocument.rectangles;
          for (i = rects.length; i--;){
               if (rects[i].graphics.length == 0){
                    rects[i].remove();
          • 2. Re: Unused Rectangle frame removal
            This indeed works perfectly.
            However I have emedded the rectangles inside a text frame, as i used tabs on some fields.
            I am unsure why the rectangles object is not removed when this is case.
            I select one rectangle item and on JAVAScript Console execute app.selection[0]
            it correctly returns as Result: [object Rectangle]
            it would be nice if there was a more detailed method to return full information.
            I guess there is some differences in details when part of an embedded.rectangle my knowledge at the moment is unable to find this.
            Thanks for your time.
            • 3. Re: Unused Rectangle frame removal
              Shonkyin Level 3
              Use this code for removing box within stories.
              var myStories = myDoc.stories;
              for (var a= 0; a<myStories.length; a++)
                   var myPictureBox = myStories[a].rectangles;
                   for (p = myPictureBox.length-1; p>=0; p--)
                        if (myPictureBox[p].graphics.length == 0)
                             myPictureBox[p].remove();
              Shonky
              • 4. Re: Unused Rectangle frame removal
                This works perfect.
                I will learn from your information. I hope other people can also find it helpful.
                Thanks to this forum for such expert advise.
                WBR
