2 Replies Latest reply on Aug 3, 2007 8:01 AM by Brian Michel
    Dreamweaver CS3 showing Hidden Files and Folders
    Brian Michel
      Dreamweaver CS3 is now showing all of the hidden files and folders when I use any of the insert dialogue boxes. I currently use an intel-based MacBook Pro. It happended after I used terminal to show all files and then hid them again. But, the Dreamweaver dialogue boxes still show the files and folders that should be hidden. All of my other programs operate properly and none of the hidden files and folders, likewise, can be viewed in Finder or Spotlight. While I can still work with the program, it certainly slows me down with so many more folder options than I am use to seeing. Does anyone have a solution to get Dreamweaver to revert back to not showing hidden files and folders.
      Thanks.
        • 1. Re: Dreamweaver CS3 showing Hidden Files and Folders
          Level 7
          From the expanded site panel, VIEW | Hidden Files?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Brian Michel" <webforumsuser@macromedia.com> wrote in message
          news:f8ucrv$rd9$1@forums.macromedia.com...
          > use
          > Pro.
          > again.
          > the
          > While
          > more
          > Thanks.
          • 2. Re: Dreamweaver CS3 showing Hidden Files and Folders
            Brian Michel Level 1
            Murray,
            Thanks for the suggestion but that is not where my problem is. It is when I use the "Insert" command from the top program menu and when I go to insert and Image or media such as Flash, my dialogue box shows everything even what it should be hiding. I have made aure that my commands in Terminal were to hide all hidden folders, etc. I guess I could try a reinstall if this bugs me too much, huh?
