7 Replies Latest reply on Sep 2, 2010 11:47 AM by Günter Schenk
    Search Form
    reandre68 Level 1
      I want do develop a search form that can filter 4 different fields. Let me explain:
      The search form consists of 4 drop-down menus. The drop-downs comprise a group (a group is 4 categories, Province, City, Accommodation type and price range). I want the user to select his criteria from the 4 menus on the same page (Let's say he chose Province:Gauteng, City:Pretoria, Accommodation type:Hotel, Price Range:R501-R1000), then when he clicks on search, the results page must show the results as per his criteria, i.e Only hotels in the Province Gauteng, the city Pretoria and within a price range of R501-R1000.
      Please anybody who can advise me on how to do this, I will be forever grateful.
        • 1. Re: Search Form
          reandre68 Level 1
          Thanks for all the replies. LOL
          Anyway I found a bit of code and edited it accordingly. It gives me an error saying: Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource but I suspect the problem lies within my query. I just can't figure out what it is. I have FULLTEXT indexing on the four columns.
          Please can someone have a look at it and tell me what's wrong?
          <?PHP
              $term = "'Gauteng', 'Pretoria', 'Hotel', '500.00'";
              $sql = "SELECT *, MATCH(province, near_city, accomm_type, norm_price_range) AGAINST('". $term ."') as score FROM travel choice WHERE MATCH (province, near_city, accomm_type, norm_price_range) AGAINST('". $term ."') ORDER BY score DESC";
              $query = mysql_query($sql);
               while($result = mysql_fetch_assoc($query)) {
                echo("{$result['near_city']} - {$result['score']}");
          This is only a test run of my actual search page, but it's based on my actual DB.
          Looking forward to hearing from y'all.
          Regards
          • 2. Re: Search Form
            Günter Schenk Level 4
            According to the MySQL documentation "AGAINST takes a string to search for, and an optional modifier that indicates what type of search to perform. The search string must be a literal string". The current value of your variable $term is actually a comma-separated list of values, which are all enclosed in single quotes -- but that´s certainly not the expected "literal string", and hence I assume that this is why you´re getting this error.
            What happens when you turn this into a literal string, like:
            $term = "Gauteng Pretoria Hotel 500.00";
            Cheers,
            Günter
            P.S. You may have wondered why you´re not getting many replies in these forum except for mine so far. The forum name "PHP Application Development" as such is somewhat misleading, because in here it´s all about questions which are related to the Dreamweaver extension ADDT, which generates non-standard PHP code and has been discontinued over a year ago. That said, these forums have become pretty quiet by now, and the number of fellow forum participants is much larger in the regular Dreamweaver Application Development forum, which - unlike this one - is made for posting questions about regular PHP stuff.
            • 3. Re: Search Form
              reandre68 Level 1
              I will test your suggestion later today and get back to you, thanks.
              I have another question, not related to the topic, hope you don't mind answering.
              When I upload a specific set of pages to my web server they come out blank??? Strangely enough it is only the pages with a database connection? I have no clue why?
              <?php require_once('../Connections/LastMinuteConfirm.php'); ?>
              That is what I use to connect to my DB
              And this is the file you see in the path above-
              <?php
              # FileName="Connection_php_mysql.htm"
              # Type="MYSQL"
              # HTTP="true"
              $hostname_LastMinuteConfirm = "";
              $database_LastMinuteConfirm = "";
              $username_LastMinuteConfirm = "";
              $password_LastMinuteConfirm = "";
              $LastMinuteConfirm = mysql_pconnect($hostname_LastMinuteConfirm, $username_LastMinuteConfirm, $password_LastMinuteConfirm) or trigger_error(mysql_error(),E_USER_ERROR);
              For obvious reasons I have removed my username, etc.
              what could be the problem?
              • 4. Re: Search Form
                reandre68 Level 1
                I have enabled error report and it says access denied. I am 100% sure that I have the correct access details though.
                • 5. Re: Search Form
                  Are you trying to connect to a remote database, that is, running this script from your localhost while trying to connect to a database which your ISP provides ?
                  Cheers,
                  Günter
                  • 6. Re: Search Form
                    reandre68 Level 1
                    Yes, and thank you for letting me know, I never even thought of it that way. I entered my IP into the remote databse host and now it works. Thanks again.
                    If I upload my page to the server it works as well, but only after I entered the server's shared IP into the same remote host field. Do you know why that happens? I want to access my DB directly if my page is uploaded and not through any shared hosting whatever that means.
                    • 7. Re: Search Form
                      Your ISP seems to impose more restrictions than another ISP might consider to be important.
                      Cheers,
                      Günter
