1 Reply Latest reply on Jul 31, 2007 7:33 PM by Tazmun
    adding images on top of a background
    hygieneboy
      Im trying to do something that should be very easy.......I have two divs in my code that look like this:
      <div id="header">
      <img src="../Extraimages/goldishheader.png">
      </div>
      <div id="main">
      </div>
      I have some CSS code that looks like this:
      #main {background-image: url(../Extraimages/blueblackgradientbackground.png);
      width: 800px;
      height: 800px;
      position: absolute;
      top: 8px;
      left: 4px;
      #header {top: 68px;
      left: 7px;
      My intent was to use the CSS code for the "main" div and set a background gradient that I created in Fireworks. The background shows up fine, just like I want it.
      However, the issue is with the "header". I have created a separate file in fireworks called "goldishheader" that I want to insert on top of the background. With the code written as is, it is inserted behind the background, therefore not visible.
      I used the z-index coding, but it did not deliver consistent results. Am I missing something??
        • 1. Re: adding images on top of a background
          Tazmun Level 1
          quote:
          <div id="header">
          </div>
          <div id="main">
          </div>
          width: 800px;
          height: 800px;
          position: absolute;
          top: 8px;
          left: 4px;
          #header {top: 68px;
          left: 7px;
          Try it this way, putting the header div inside the main div. Z-index only works if your using layers, which you have not established on both divs. Main is actually set up to be a layer as you have it though, where header is not
          <div id="main">
          <div id="header">
          </div>
          </div>
