1 Reply Latest reply on Aug 30, 2010 10:35 PM by skarthiks
    What software does Adobe have to create Flash from Java
    vets-are-fun Level 1
      What software does Adobe have to create flash from Java programmatically (I need to automate this process). Should I be looking at FlashPro or something else?
      If Flash Pro, how is this done? A direct API or through some type of XML interface? Where is this documented?
      Thanks Guys:
        • 1. Re: What software does Adobe have to create Flash from Java
          skarthiks Level 2
          I guess, you are asking if you can compile a java program as a flash file and if there is a offering from Adobe for that.
          Nope, Adobe does not offer a compiler to convert java to flash file.
          Although, Flash Pro has a language called "ActionScript" which is an equivalent language to Java.  You can use Flash Authoring Tool (Flash Profesional) to author flash files and then convert it to a swf.
          Hope this helps
          Karthik
