2 Replies Latest reply on Aug 30, 2010 1:26 PM by Devtron
    NULL Text problem with DataGrid SelectedItems
    Devtron Level 3
      Hello,
      I need to create a string based on the name property on rows in a DataGrid.
      here is my code:
                          //get devices names
                          var idx:uint;
                          var len:uint = dg.selectedItems.length;
                          var deviceNames:String;
                          for (idx = 0; idx < len; idx++) {
                              deviceNames += dg.selectedItems[idx]["name"].toString() + ", ";
      Whenever I trace or display the deviceNames string, it has "null" at the beginning, like this:
      "nullDevice1, Device2, "
      Why is null appearing? I have tried to remove it, replace it, and nothing.
      I know you can use replace or concat, but neither of those work. There are only two rows in my datagrid. I dont know why NULL is even appearing at the beginning of the string. I have changed the loop dimensions, because I thought maybe it was not zero-based, but still no luck.
