3 Replies Latest reply on Aug 31, 2010 11:37 PM by Vikash.kumar29
    How do I prevent a record from being copied?
    SiHoop Level 1
      The following code creates a datagrid. Records in the datagrid can be moved via click and drag. But the record is copied if the user presses the control key while dragging a record.
      How can I prevent the copy from occurring?
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"  creationComplete="init()">
          <mx:Script>
              <![CDATA[
      [Bindable] private var myXml:XML
      private function init():void{
          myXml=
              <TABLE>
                 <EXAMPLE>
                    <difficulty> 0.8152</difficulty>
                    <discrimination> 0.4259</discrimination>
                    <item> 2 </item>
                 </EXAMPLE>
                 <EXAMPLE>
                    <difficulty> 0.8641 </difficulty>
                    <discrimination> 0.3707</discrimination>
                    <item> 4 </item>
                 </EXAMPLE>
                 <EXAMPLE>
                    <difficulty> 0.5706 </difficulty>
                    <discrimination> 0.2631</discrimination>
                    <item> 6 </item>
                 </EXAMPLE>
              </TABLE>
          </mx:Script>
          <mx:DataGrid x="500" y="200" dataProvider="{myXml.EXAMPLE}" width="200" height="300"  dragEnabled="true"  dragMoveEnabled="true" dropEnabled="true" >
              <mx:columns>
                  <mx:DataGridColumn headerText="Item" dataField="item"/>
                  <mx:DataGridColumn headerText="Discrimination index" dataField="discrimination"/>
                  <mx:DataGridColumn headerText="Difficulty" dataField="difficulty"/>
              </mx:columns>
          </mx:DataGrid>
      </mx:Application>
        • 1. Re: How do I prevent a record from being copied?
          Subeesh Arakkan Level 4
          Listen for the drag drop event and change the action from copy to move on the fly.
                    dragDrop="datagrid_dragDropHandler(event)">
          private function datagrid_dragDropHandler(event:DragEvent):void
               if(event.action == "copy")
                    event.action = "move";
          • 2. Re: How do I prevent a record from being copied?
            SiHoop Level 1
            This works perfectly-- thank you!
            However, if the control key is pressed during a drag-drop, the cursor changes to show a small green +-sign. How can I prevent this from happening? What is the property that is set to change the cursor?
            • 3. Re: How do I prevent a record from being copied?
              Vikash.kumar29
              add an event listner for dragStart,dragEnter and  dragOver on the dataGrid like :
              <mx:DataGrid x="500" y="200" dataProvider="{myXml.EXAMPLE}" width="200" height="300"            dragEnabled="true"  dragMoveEnabled="true" dropEnabled="true"           dragDrop="datagrid_dragDropHandler(event)" dragOver="checkDragHandler(event)" dragStart="checkDragHandler(event)" dragEnter="checkDragHandler(event)">
              and handler as :
              protected function checkDragHandler(event:DragEvent):void
                   if(event.ctrlKey)
                   event.ctrlKey = false;
              This do help me. Hopes also works for you.
              -Vikash
