0 Replies Latest reply on Aug 30, 2010 4:37 PM by yalnam
    Encoding Quality Difference Between Premier and After Effect
    yalnam Level 1
      I try to encode DV NTSC Premier project which contains just 2 JPG files  with maximum quality.(Uncompressed AVI)
      And with just same method encode AfterEffect composition.(Uncompressed AVI)
      Can I get same result both Applications?
      The result is so different. After Effect shows much more better quality.
      So everytime I have to  bring Premier job to AfterEffect again each clip copy and paste.
      (There is another problem Dynamic Link, so I can't bring whole sequence)
      Example:
      1. 2 jpg clips are connected with cross dissolve in Premier.
      2. Copy and Paste all Premier clips to AfterEffect composition.
      3. NO dissolve applied. What the~...
      4. more strange thing is this is not happended every clips if you apply same transition several clips streak.
      Anyway... my major concern is encoding.
      Once more .. Can I get same encoding result between Premier and AfterEffect?
