2 Replies Latest reply on Aug 31, 2010 3:47 AM by rootsounds
    Difference between flex & CS5
    learner2010
      We need to build a graphical user interface for an engineering application, which requires controls like a flowcharts(circle, rectangles,squares ) and be able to dynamically control the color of these controls(from a java application using XML).
      Currently we are using flash CS2 for this..but the application development is getting complex(since for each graphics object type/shapes) we are creating different frames in the flash and the scripting logic is quite difficult to maintain.
      The GUI that we are trying to create is like an engineering block diagram of device connectivity.
      Will using the flex IDE, make the development like a GUI programming using VC++/Java swing ?. We should be able to do simple event handling (like click etc.,)
      Appreciate your inputs on this
