4 Replies Latest reply on Aug 5, 2007 11:34 PM by Lacito_Domingo
    Bound methods and garbage collection
    Lacito_Domingo
      In the example you can see that I create a TestClass instance. In the constructor of
      TestClass I set the "f" property. As you can see there are no references to the XClass
      instance but it's "foo" method is extracted from the XClass instance and is stored in the "f"
      property.
      The question:
      Does the garbage collector remove the XClass instance from the memory?
      I think it can't remove it, because the bound method (which is store in "f") reference to it (this).
      (But if I set the "f" property to null the garbage collector will remove it.)
      Can you confirm it?
      Lacito
      The example:
      class XClass
      function foo():void // bound method defined
      class TestClass
      protected var f:Function = null;
      public function TestClass()
      f = new XClass().foo();
      var myTest:TestClass = new TestClass();
